I cannot figure out how to change staff and print size in notion mobile. Printout is so small. I used to be able to do this in the old mobile version. Can anyone lend a tip?
After you select Print on Notion Mobile, a pop-up window shows up on your device. You can find the scaling options on that menu. The pop-up windows differs from devide to device but it works same on all the devices. Thank you Sinan
Sinan C. Eroglu
QA Specialist at PreSonus Software Ltd, Hamburg, Germany --------------------------------------------------------------- iMac Pro Intel i9 128GB RAM, 16 Core GPU, 1TB SSD MacBookPro Intel i7 8-Core GPU, 16GB RAM 256GB Flash SSD MacBook Air M2, 8GB RAM, 500 GB Flash SSD Mac Mini 2,6 GHz Dual-Core Intel Core i5, 16 GB RAM iPad Pro 12.9 (5th Generation) RME Fireface UCX Official Artist of Kemper Profiler, EMG Pickups, GHS Strings Spotify: https://open.spotify.com/artist/5bAM9... http://sinancemeroglu.com http://youtube.com/sinancemeroglu |
Yes, I know how to scale the printout using the operating system dialog. When you do that the notes and staff go outside of the print boundaries. Unless I’m missing something, the document doesn’t fit inside the printed area.
I was hoping that there is way to make the actual score document use larger notes and font? |
