When we write tremolo or roll in the drum, we always use joint lines, which are from the same note to the same note, and all joint lines are deleted when viewed in partbo.
So, if you enter the joint again, the joint in the line will be revived again. If you close the file and open a new one, you can't see the joint again. If you draw the joint again and print it, the joint does not show. This seems to be a bug. If you can't check it, I'll take a video and send it to you. Please give me your email address. |
