I looked in Score Setup and couldn’t find anything. For example, if I want my score to have 4 or 6 measures in every stave, is there a way to set that up?
I’ve created a new score and some of the measures are too narrow. For example, when measures only contain a whole note, Notion Mobile makes adjusts them so narrow that the score doesn’t look as readable (professional) as I’d like it to look. Any suggestions, anyone? Thanks! |
Yes, it is possible. For example if you want to have 6 measures for every stave, please go to: Layout > Print View > Score Systems > Measure Limit On that menu, you can easily adjust the measure numbers that will be shown at each stave. If you think that some measures are too narrow, and you want to move the next measure to the next stave, then double tap the measure that you want to move down > Measure > Force New System Thank you Best Sinan
Sinan C. Eroglu
QA Specialist at PreSonus Software Ltd, Hamburg, Germany --------------------------------------------------------------- iMac Pro Intel i9 128GB RAM, 16 Core GPU, 1TB SSD MacBookPro Intel i7 8-Core GPU, 16GB RAM 256GB Flash SSD MacBook Air M2, 8GB RAM, 500 GB Flash SSD Mac Mini 2,6 GHz Dual-Core Intel Core i5, 16 GB RAM iPad Pro 12.9 (5th Generation) RME Fireface UCX Official Artist of Kemper Profiler, EMG Pickups, GHS Strings Spotify: https://open.spotify.com/artist/5bAM9... http://sinancemeroglu.com http://youtube.com/sinancemeroglu |
