Notion Mobile 3.3.1: Mar 2024
Guide: https://shorturl.at/qBXY1 Playback NS-4207 Repeat signs are now played back as expected if there is both an end and start repeat on the same barline, and that the score was created in an earlier version NS-4220 Snare roll now plays as expected Export NS-3922 Network transfer to Notion running on an iOS17 or later device, now works as expected NS-4210 [iOS] Noteheads now line up as expected on the staff in pdf export or direct print NS-4218 Can now transmit wav files to Studio One as expected UI NS-4199 [MacOS] Arrow sign doesn't skip to the next note for adding a chord NS-4203 [mac/Win] New score items now update as expected when being edited with a picker (e.g. chord picker, time signature dialog etc) Layout NS-4226 Double/repeat barlines can now only be dragged when a layout handle is visible NS-4230 Rehearsal marks now movable after being dragged outside of their measure NS-4200 Fill with Rhythm Slashes now works as expected on grand staff instruments Note Entry NS-4205 Entering an 8th note chord following a 16th note triplet chord now enters the expected note NS-4209 Adding a new barline no longer moves all attachments in existing bars NS-4212 Changing the Staff Type of a fretted instrument (e.g. ukulele) no longer reverts TAB to Guitar NS-4215 Adding a slur in one voice now does not delete existing slurs in another. NS-4217 Adding lyrics for additional verses is again now possible on the last staff of a piece General NS-4108 [iOS/macOS] Improvements to location and document handling General stability improvements Notion Mobile 3.3: Feb 2024 Guide: https://blog.presonus.com/2024/02/27/no ... available/ Notation NS-2927 Harp Pedal Diagrams and Harp Pedal aid NS-4066 Melismas now carry over systems NS-4086 Tuplets can now be forced above or below notes NS-4038 Note spacing between different voicings improved NS-4083 Measure number changes now possible NS-4090 Custom beaming patterns TEC-1660 Lyric spacing improvements NS-4082 Mandolin chord diagrams now included SO-15332 Notation spacing improvements NS-4127 To Coda and Coda markings now show text as well as symbol, and are aligned as expected NS-4135 Single digit bar numbers no longer overlap with notes on ledger lines NS-4160 Staff bracket groups created in Notion 6 desktop now show in Notion Mobile NS-4163 Stem length for beamed notes with ledger lines is now correct for grand staff instruments NS-4164 Note spacing improved when both tab and standard instruments are in the same system NS-4175 Lyric display improved if notes are made into cross-staff notes NS-4177 Tuplet beam no longer continues to another tuplet if group ends with rest NS-4178 Tuplet brackets now only added to those tuplets selected NS-4180 Tuplet numbers no longer occasionally collide with note stem/tail NS-4183 Rest is no longer inserted as a triplet if it is added before the triplet Note entry NS-4153 Can now add a chord note via onscreen keyboard/fretboard without overwriting the existing note(s) NS-4157 Notes in enharmonically substituted key signatures for transposing instruments now enter as expected NS-4159 Can now enter range objects (e.g. slur) with single tap between two notes NS-4165 Handwriting recognition now works as expected in measures that end with a double bar line NS-4168 Glissandi now enter more reliably NS-4169 Alterations of tensions now not allowed if no 7th is present in the chord Playback NS-4190 Context menu now closes when Application or Layout Menu is opened on touchscreen NS-4191 Fermata now holds the notes on both staves of grand staff Layout TEC-1654 New Layout Control features. Available as part of the Feature Bundle UI NS-4032 Add new instrument icon now shows if no instruments are added to a new score NS-4054 Issue when clicking/touching to increase the time signature fixed NS-4036 Username prompt removed from log-in dialog NS-4091 Missing localizations fixed NS-3804 ‘About’ Notion Mobile in macOS menu bar fixed NS-4092 Instrument names now show in English, when application is set to Korean or Chinese NS-4144 [iOS] Text box no longer extends beyond the text area NS-4147 Dynamics and articulations show as expected during dragging NS-4087 Onscreen fretboard now shows blue dots whilst playing MIDI instrument NS-4150 mp3/FLAC option sliders showing as expected NS-4170 Instruments now show as expected in mixer if accidentally selected and hidden NS-4181 [Android] Alignment problem fixed in Export dialog NS-4186 Buttons more responsive when tapped quickly (e.g. Copy) NS-4194 Accidental note entry is now prevented when closing context menu NS-4195 Application Menu no longer occasionally unresponsive General NS-4033 New document recovery options NS-4109 Keyboard shortcut for 'Save As...' now Ctrl+Shift+S across platforms (Cmd+Shift+S on macOS and iOS) NS-4110 Application Menu items added for 'Save' and 'Save As' TEC-1729 [iOS] Occasional issue reopening document with character accent in filename fixed TEC-1775 [Android] Studio One+ membership now remains active General stability improvements Documentation updated Notion Mobile 3.2.4: Nov 2023 Guide: https://shorturl.at/exEOR General General stability improvements NS-3999 Improvements to rhythm conversion after real time recording: NS-4089 In-app purchase issue resolved in Samsung Galaxy Store Playback NS-4023 Note no longer hangs when clicking tab while an existing tab edit box is open NS-4059 Drum rolls now play back as expected when score is reopened NS-4062 Playback fixed for specific instruments when playing with virtual keyboard: (harpsichord, bell tree, sand blocks, whistle, ukulele, banjo) NS-4069 After changing the instrument, playback is now possible if there are trills NS-4088 Tremolo playback now completes with tied notes Sample Rate NS-4068 [Android] Optimal sample rate for Notion Mobile on Android now selected TEC-1704 [Android / Windows] Sample rate no longer resets on app restart / changing block size NS-4084 [Android] Sample rates now written in order from smallest to largest UI NS-3822 Background of start page unlock icon is no longer transparent NS-4072 Long file name now fits the text box in the Export dialog window NS-4056 [Android] Rendering issues fixed on score setup page NS-4123 Number now visible when typing in ‘Insert Measures’ dialog NS-4124 Popups can now be dismissed while overscroll animation still running NS-4126 [iOS] Issue fixed when tapping away from ‘Insert Measures’ text box NS-4134 [Android] Keyboard disappears as expected when dismissing dialog box Notation NS-4107 Accidentals preview displayed as expected when entering with mouse NS-4112 Spacing increased between chord symbol and notes above the staff NS-4050 Minor Chord symbols no longer overlap NS-4067 [Windows] Rehearsal letters are now aligned properly when using Jazz Font NS-4094 Change Instrument now uses the default instrument name NS-4096 Page Numbers now appear as expected in parts on reopening file NS-4103 Issue adding / removing ties in some cases resolved Notion Mobile 3.2.3: Oct 2023 Guide: https://shorturl.at/etuEL Performance and stability enhancements NS-4039 Text box is unresponsive after tapping on the score NS-4040 [macOS] Mouse cursor stops moving after text box committed NS-4043 [Windows] Pressing 'Enter' to commit lyric triggers warning chime NS-4044 Repeat sign adds a empty measure to the beginning if clicked off the page in print view NS-4048 Users cannot download Core Sounds without registering TEC-1660 Lyrics placement improved SO-15256 Undo can cause issue when entering notes Notion Mobile 3.2.2: Aug 2023 Guide: https://shorturl.at/dENX0 Performance and stability enhancements NS-3917 Ukulele and banjo strings in the onscreen fretboard now drawn as expected NS-3936 Transpose key option shows as expected in C major and A minor NS-4011 Quarter and eighth note on same pitch in different voices now share the same notehead as expected NS-4013 Metronome click no longer plays one more beat at the end of the project NS-4014 Alignment problem on different voicings fixed when augmentation dots are present NS-4015 [iOS] Select part now does not always select the first part NS-4016 Next note sounds as expected when glissandi / portamenti are not connected to an end note NS-4017 Copy / Paste no longer creates unintended shifts on multiple instrument scores that also contain multi-voice instruments with underfull measures and a time signature change. NS-4018 Issue fixed when trying to insert objects into empty score when no parts are present yet NS-4020 Mouse preview now updating when using keyboard shortcut to change duration NS-4021 Can now edit title text if no instruments are present NS-4025 [Android] The dots for the repeats and notes now appear as expected in Acrobat after PDF export SO-15021 Entering TAB on the 7th string is now possible SO-15193 Ties now taken into account when pasting lyrics with hyphens Notion Mobile 3.2.1: July 2023 Guide: https://shorturl.at/CDEQ6 Performance and stability enhancements NS-3997 Tab button is not skipping to next beats when entering lyrics NS-3998 Title font size numbers become 11.00 if the title font is changed NS-4001 NTempo is ignored by Notion 6 playback after export from Notion Mobile Improved chord labels in chord selector for b7 / °7 / half diminished chords. Notion Mobile 3.2: July 2023 Guide: https://blog.presonus.com/2023/07/18/no ... available/ Availability Notion Mobile is now part of Studio One+ (the new name for PreSonus Sphere) Notion Mobile can now be found in the Samsung Galaxy Store Notation Mid-staff Instrument change now possible (Shift+I) Slides and glissandi can now be added to grace notes Pedal up/down tool now available to Vibraphone Different harmonic type text now available for score entry: Harp Harmonic (HH), Tap Harmonic (TH), Pinch Harmonic(PH) Increased spacing between a time signature change and any following accidentals Cross-staff tuplet number no longer shows between staves Stems on cross-staff notes now show correctly when beam is dragged Beam is now shown on correct side if all notes in a group are cross-staff Fingering numbers can now be stacked vertically for chords Finger substitution dashes and numbers now can be added (hold shift while adding the finger number) Notes do not now overlap when they have different durations and in different voices Issue fixed where on some occasions a gliss could not be added to the 3rd beat Editing New ‘Fill with Rhythm Slashes’ tool (Context menu>Tools) Can now paste lyrics text from an external source (e.g. system clipboard) Can now advance lyrics on iOS with tab key (as well as space) Entering lyrics after a melisma now does not skip the next note Adjusting lyrics text size no longer changes the font on Android Can now flip a tie below/above notes (Context menu>Attachments>Show Above/Below, or Ctrl+Shift+F) Can now hide the tuplet number (Context menu>Make Custom Tuplet>Hide Number) Fingerings can be realigned (Make a selection>Context menu>Tools) Tempo markings can now be shortened, hidden, and deleted (Make a selection>Context Menu>Attachments) Measure tools in the Context Menu now affect the measure in which the menu was opened (rather than where the caret is located) Note Entry New ‘Transpose Entry’ option in Options>Record Setup. This will transpose notes entered with both a MIDI instrument, and with the onscreen instruments Entering tuplets with different durations improved Chords Maj9 chords now play back as expected (i.e. not as dom9) Better handling of chord alterations (e.g. C13b9) Layout Titles on following pages can now be set at different sizes to page 1 as expected UI Palette spacing improvements Tooltips added for the Tools Grid Text now shows as expected when renaming scores (Android) Drumpad octave up/down buttons now represented with arrows General Soundsets now retained when device is low on storage (iOS) Rests are now not added to measures that have a one-measure repeat sign on MusicXML export Sound Installation buttons now responsive after removing sounds (Android) Pending Purchases now supported on Amazon (i.e. when a purchase is made by a Kids Profile and requires Adult account approval) Documentation updated Notion Mobile 3.1.2: Jun 2023 Guide: https://shorturl.at/lvIKR Performance and stability enhancements NS-3953 Custom chord names change if the chords are written with diagrams NS-3915 Lyric spacing improvements NS-3944 Double clicking an end repeat barline to create multiple repeats now works on the last measure of a long score NS-3957 Repeat barline on the final bar is now playing back as expected NS-3940 Repeat sign is deleted after XML export / import NS-3934 Notion suddenly zooms out (to maximum) on Android (especially when using trackpad on Chromebook to zoom in) NS-3945 Capo is not showing the right enharmonics in step record mode NS-3946 Ties in Drum parts disappear when you close a score and reopen it in Notion Mobile Notion Mobile 3.1.1: Apr 2023 Guide: https://shorturl.at/fgAG2 Top Fixes Export as mp3 now showing as expected in Export menu Sound Downloads now not failing in some circumstances More space created between Lyrics when words are longer When zooming on Android, notes are not entered when lifting one finger Chords Allow entering chord symbols and diagrams on the following beat when a measure is full (e.g. chords over a single whole note) Chord Summary now shows other instruments e.g. ukulele, rather than always guitar Entering chords in Step-mode now enters the last chord in a measure as expected Chords entered over an empty bar are now not moved when notes entered General In app keyboard now showing as expected when scaling (Windows) XML Export now not duplicating the last measure in some circumstances Select part now selects as expected in Print / Continuous View Hiding resting staves now working if there is a Segno present Double at interval tool now includes ties if they are present Changing Title in the Layout Menu for following pages, now does not affect the first page’s title Slur ends now not overlapping on whole notes Tempo change target bpm is now shortened when displayed Improve lyric placement of long words/syllables Context menu does not open if selection is behind quick action menu Notion Mobile 3.1: Mar 2023 Guide: https://blog.presonus.com/2023/03/22/no ... available/ Notation Time signatures can now be hidden The stem of a grace note now shows when added to a note inside a tuplet Text placement of e.g. Title is now centring when moved back to Top Center Barlines no longer extend outside of system when printing with hidden resting staves Lyrics with short words are now better aligned to the note Multiple lyric hyphens under notes can now be entered Tuplet number now shows on correct side when stems are forced down Tuplet brackets show as expected when tuplet starts with a rest Slurs in guitar tablature now display correctly between two notes Stems show as expected on cross-staff glissandi Cross-staff notation improvements Cross-staff tuplet number now shows under beam rather than between staves Tails on cross-staff notes now show as expected O / + symbols now available for harp, French Horn Editing Lasso select Delete final measure now works as expected when part of a selection All text size numbers are now showing (e.g. when increasing size to 27.50) Text boxes display where expected when editing [macOS] Line breaks in text boxes can now be made with Shift+Enter Adjusting font size now works as expected when decreasing down to 28 [iOS] Font now does not change when adjusting size ‘Remove Tuplet’ tool added to Context Menu Tremolos now toggle “on/off” when tapping the icon or using the shortcut Diamond symbol now not occasionally showing when pasting Paste does not now overwrite time signatures before the first copied time signature is inserted Pasting a full cut/copied measure no longer pastes into the measure following the target measure When dragging articulations, note accidental previews no longer appear Copy and paste measures with ties coming into them now paste as expected Fixed double tap between systems could open the selection on the wrong system Note Entry Entering notes at the end of a score automatically adds new measures in both step time and real time Tuplets now working as expected in step time entry Advancing in Step time no longer removes open ties from chords [Android] Preview note no longer displaced when entering tab on the first beat of the bar Fixed applying augmentation dots to selected note when pressing the augmentation dot button in the palette (as opposed to using the keyboard shortcut) Handwriting recognition now works as expected following a clef change Chords Add multiple chords to empty measures More chord extensions available to combine More chord diagrams available for guitar and ukulele Chord diagrams now sorted by fret position Chord placement improvements, including placement under repeat brackets dim7 chords show as expected Measures space as expected with chord symbols over the top Two digit fret numbers no longer overlap with tab in chord diagrams Parts Toggle between score and selected part with keyboard shortcut (F5) Score / Part icon toggle redesigned in Score Setup menu Hide key signature option in instrument setup (e.g. for French Horns) Part titles now inherited from full score by default Part name on top left of page includes key by default (e.g. Clarinet in A) Anacrusis / double barline now not breaking a multi-measure rest Rehearsal / metronome marks no longer create individual bar rests during a multi-measure rest Playback Playback selected staves only Display no longer auto-locks during playback Preview note entry dynamics are now mf Playback of microtones now sound as expected Metronome count-in for compound time signatures now clicks as expected Sounds load as expected for template files Playback improved for imported MIDI trills [Android] Playback improved on entry level devices Clarinet now plays back (sounding) Db3 for Clarinet in A (remove and re-download the ‘Wind’ sound bundle to fix). UI New button added to toggle between normal and extended width palettes Handwriting (‘pencil’ icon) now visible in both normal and extended palettes [Android] Placement of popup faders improved [Android] Sub-menus now open as expected when in split screen mode [iOS] Can now swipe up on the iPhone screen when in Instrument Picker Can now select sub-tools from palette when on small screen Sheet-style dialogs like score setup now resize correctly on iOS when changing the screen orientation Removed the second text style edit option from the context menu Fixed sub-tool not being activated when tapping on it while being in the select tool [Android] When editing text in score settings, the text is now centred [Android] Open dialogs now adjust as expect if screen orientation is changed [Android] Issue fixed where application can sometimes freeze when closing dialogs/popups Metronome Tool dialog is no longer cut off by on-screen keyboard When using the small sized UI, the note duration palette is now proportioned and positioned correctly [iOS] Swiping and selecting over fly-out menus now works as expected Tuplet flyout now shows in two rows on smaller screens Distance between flyout menus and palette now consistent [Android] Instrument picker is no longer cut off at bottom [Android] Manage Features dialog now closes as expected, if still open when the app is closed [Android] Menus do now not close if a dropdown menu item is selected [Android] Text now does not exceed edit box height when entering lyrics Files New demo scores tab with 10 scores included Template files can now be double tapped to directly open [iOS/macOS] Save document to alternative location if permission denied [iOS/macOS] Browser opens if access to file is denied [iOS] ‘Clear history’ no longer brings up double entries for save locations in some circumstances 'Untitled' for new document titles is now localised in selected language Document location path cleaned up [Android] Export to PDF via Share function now working as expected General [iOS] ‘Restore Purchases’ now lists what was purchased in Notion iOS v2 [iOS] Restore Purchases now shows popup if there is an error retrieving the receipt [iOS] If region is set to USA, then measurement units do not change [FireOS] In-app purchasing fixed on Amazon Fire devices Guitar fingerings now included when exporting as MusicXML Notion now opens malformed compressed MusicXML files (e.g. a .musicxml file that has been changed to .mxl by just changing the file extension) Note heads now print at actual size when printing or exporting as pdf if Screen View is shown Translation improvements Performance and stability improvements Documentation updated Notion Mobile 3.0.4: Improvements Stability fixes and performance improvements Allow fretboard to swipe left and right New icons to access tuplet command Dark/light mode switching improvements Fixes Breath marks at barline applied too early in playback Main Channel pan issue with scores saved in Notion Mobile and reopened in Notion 6 Repeat barline at the end of a piece does not repeat Transpose key signature option is not showing as expected when the selection contains a key signature change Advancing in Step time removes open ties from chords Issue entering lyrics for verse 2 under verse 1 on the bottom staff of a system Tapping a score location during playback re-starts from the new location twice Notes that are 'tied to', are sometimes misplaced on MIDI import Notion Mobile 3.0.3: Performance and stability fixes Bug fixes: Notion not finishing at 'Fine' after DS - in playback and export Accent Shortcut (circumflex symbol (^) does not work on Mac Cannot delete final measure when part of a selection Context-menu is missing rounded corners Manage Features dialog is movable on Android Chord symbol accidentals and other symbols in Jazz Font not showing (Android) In-app purchases not possible on Windows Delete measure only deletes contents of measure, not the measure itself Context menu not showing as expected depending on scaling (Win) Note entry via real-time record is not splitting notes between left and right hands on a grand staff Chord jumps to minor from half-diminished when de-selecting the 7th Playback caret is hidden if top staff is hidden Notion Mobile 3.0.2: Issue fixed when registering for my.presonus Notion Mobile 3.0.1: Bug fixes: Fixes for iCloud Handwriting options in the Options Menu are not unlocked after 'Restore Purchases' Cannot delete final measure when part of a selection Notes only go into treble staff when using step/real-time record with a grand staff Dragging a pitch left/right on input does not take key signature into account Cross-staff beaming crashes Notion if both staves are selected License window is empty on macOS Cannot switch to English language on Android if device language is set to anything other than English Notion Mobile 3.0: October 2022 Guide: https://blog.presonus.com/2022/10/18/no ... e-is-here/ New features: Platform: Notion now a free app Native cross-platform support: iOS, macOS, Windows, Android, FireOS PreSonus Sphere Support - unlock all features and sounds with your PreSonus Sphere membership Features and sounds can alternatively be unlocked with a per platform in in-app purchase Forum access available for Sphere members, or with free registration at my.presonus.com Handwriting Recognition: Pen / finger automatic option can be chosen Now available on phone Recognition improvements 5-line drumset staff supported - notes will automatically switch to the nearest notehead (e.g. cross notehead for cymbals) Timer can be adjusted between handwriting, and the digital recognition With Apple Pencil 2, double tap the pencil to force recognition With Surface Pen, use the button to force recognition App Design: New Welcome Page Palette can be positioned on left or right side Option for large or small palette icons Option for standard width or compact palette UI can be shown in dark or light Score can be shown dark or light On-screen instruments: Keyboard key width can be changed Octave up/down buttons and range slider added to keyboard Drum pad can be used to enter pitch for non-drum instruments Capo can be edited from either the score text direction, or from the on-screen guitar fretboard Note entry: Enter up to four voices per staff Change duration of selected notes by tapping a duration on the palette Keyboard shortcuts on all platforms Option to use letters for durations (e.g. ‘e’ for eighth note) Tab notes can be typed directly into tablature staff Move notes between hands on a grand staff Show/hide stems when viewing tablature only Grace note slashes can now be hidden (so appoggiaturas can be written) New insertion caret Drum labels show when hovering over drum staff Change the accidental of a pending/existing note by dragging it left and right Change the technique of a drum pitch, by dragging a pending/existing note left and right L & R sticking for drums now added to palette Layout: Allow user to hide instrument key in score/part (e.g. Clarinet "in Bb") Selection: New selection tool is now object based rather than range based A selection can be initiated by a simple press and drag New shortcut icons for a selection for quicker copy/paste/transpose Paste Reflow paste selection into new a rhythmic position in the bar, and Notion will re-spell durations over barlines Add element (e.g. dynamic) to all selected staves at once Ability to select highest/lowest notes in a selection Selection of notes can be dragged to transpose Selection of notes can be changed to rests and vice versa Selected notes can be turned into grace notes and vice versa Selection of similar elements can be edited together by dragging. e.g. adjusting one hairpin in a selection affects all hairpins in the selection at that same position) Text: Line breaks can be added to text boxes Smart verses entry in Lyrics mode Chord symbols now do not affect note spacing if there is space for them Metronome in playback Export: Send score between Notion Mobile running on two different devices over network Send score or audio over a local network to Notion 6 desktop or Studio One 5 New export audio formats: m4a, Opus or FLAC New browser-based Help available in all languages
Product Manager - Notion
PreSonus Audio Electronics, Inc. http://www.presonus.com/products/notation-software |
