Discuss Notion Mobile here.
Hi all,
I really love Notion but have the problem that it is really unreliable for me. I often can‘t use it because it will constantly break down while starting up. A restart of the ipad or complete delete and new install doesn‘t help. A few hours later it starts up as it was nothing… next day it breaks down again. I can‘t find the reason why. Anybody else with this problem or even better with a fix?
I‘m on an iPadPro 2020 with the latest iPad OS 16.3.1
Best regards - Christoph
by christophvictorkaiser on Tue Feb 28, 2023 12:59 am
Hi all,
as noted beforeI have the problem that Notion Mobile on my iPadPro crashed right during startup and I never found out what could cause that. I normally use my iPad like an computer on my desktop and with the poweradapter plugged in. I discovered yesterday that this might cause the crashes…. when I‘m plugged in, Notion will crash, when I‘m in battery mode Notion works like a charm. After that discovery I investigated a little bit longer and found out that it might has to do with my interface RME Babyface that is plugged in a router that is connected combined with the poweradapter. When I unplug the interface Notion will run also with the poweradapter - as soon as I plug in the interface Notion crashes.
by sinancemeroglu on Tue Feb 28, 2023 3:17 am
Hi Christoph,
Here I have tried with a RME Fireface UCX with an iPad Pro and I can't reproduce this issue. Can you kindly try to update the firmware of your RME Babyface along with your iOS ? It may cause this issue.
Best
Sinan
Sinan C. Eroglu
QA Specialist at PreSonus Software Ltd, Hamburg, Germany
iMac Pro Intel i9 128GB RAM, 16 Core GPU, 1TB SSD
MacBookPro Intel i7 8-Core GPU, 16GB RAM 256GB Flash SSD
MacBook Air M2, 8GB RAM, 500 GB Flash SSD
Mac Mini 2,6 GHz Dual-Core Intel Core i5, 16 GB RAM
iPad Pro 12.9 (5th Generation)
RME Fireface UCX
Official Artist of Kemper Profiler, EMG Pickups, GHS Strings
Spotify: https://open.spotify.com/artist/5bAM9...
http://sinancemeroglu.com
http://youtube.com/sinancemeroglu
by christophvictorkaiser on Tue Feb 28, 2023 4:50 am
Hi Sinan,
thank you very much for your reply. I have the RME Babyface Pro and did the flash update like you suggested, but Notion still crashes as soon as I connect the Babyface to my hub.
I‘m on the latest iPad OS 16.3.1
It took me quite some time to find out that the crashes relate to the Babyface…
by acequantum on Tue Mar 14, 2023 4:53 pm
just chiming in here... as a test, try setting the Baby face Pro to Class Compliant mode and see if that makes any difference
by christophvictorkaiser on Tue Mar 14, 2023 5:00 pm
Hi acequantum,
thank you very much for your post and for trying to find a solution. The babyface is already in CC mode - I think it would not work with the iPad if I would choose the other mode.
by acequantum on Tue Mar 14, 2023 6:41 pm
Hmmm, it was worth a shot. Do you have your Baby Face Pro plugged into a power source? Not just the usb port of the ipad? I didn't understand from what you wrote whether you had the Baby Face Pro plugged into it's own power source.
I'm assuming you are running the USB out from the Baby Face Pro and using an adapter to convert the USB Type A plug to a USB type C to plug into the Ipad, is that correct? Could the adapter or cable be damaged?
by christophvictorkaiser on Wed Mar 15, 2023 12:54 am
Hi acequantum - thanks for the continuing troubleshooting ideas.
I have the Babyface Pro plugged into an hub which is powered by a strong apple adapter so there is enough power to keep the Babyface alive and it can charge the iPadPro.
I never plugged the Babyface directly into the iPadPro - in order to do so I would need an USB A to USB C adapter…
I can just tell that all other apps that work with sound and use the Babyface Pro like Cubasis, Safari, YouTube etc don‘t have that problem - so I don‘t think it belongs to a corrupted cable… but you‘ll never know. I will investigate.
by acequantum on Thu Mar 30, 2023 1:05 pm
Did you try the new update? For me it seems some things are fixed like I am able to transmit scores between Notion 6 and Notion Mobile.
by christophvictorkaiser on Thu Mar 30, 2023 1:23 pm
thanks for asking - there are indeed some good fixes, especially the templates working again. But my issue with interface is still active.
