Hello,
I would like to use an AudioBox GO to livestream a mono aux mix from a Series 3 mixer. I know that the board itself has digital audio capabilities but It will be too far from the broadcasting computer (120 feet) for USB audio and the broadcast computer does not support AVB audio. The series three aux output is 100 ohms and +24dBu max. The mic pre amp on the GO is 1.4K ohms and +10dBu max input. This seems like it should work but wanted to see if anyone could provide relevant input before I purchased the GO.
Thanks for any input!
by SwitchBack on Tue Mar 28, 2023 4:03 pm
Hi and welcome to this forum :)
Yes, the AudioBox GO will do fine but you'll have to use the line input. So use a cable with a TRS plug/adapter at the GO end. That way you'll minimise cable losses and do not run the risk of feeding phantom power into the mixer output.
