I'm wondering, if there is a good way to output my mic only to my headphones but not the monitor speakers, as they are in the same room and thus cause feedback. I still want the playback to be audible via headphones and speaker.
I can think of solutions like: - mute my mic, when unmuting the speakers (which is quite annoying when done often, especially as there is no physical mic mute option.) - mute the mic in the main mix in the software. Then monitor mix B, where mic and playback are audible, with headphones (problem here: headphone monitoring resets to main mix after the interface is powered down. So you have to go into the software every time to change that.) (Also it's kinda annoying that the interface doesn't remember after poweroff wether stream mix, input mute or headphone monitoring was active.) Maybe I'm overseeing something, but otherwise it would be nice to somehow implement this feature with an update in one of the mentioned ways |
