Burn in on OLED?
Posted: Fri Sep 17, 2021 8:53 pm
Hi there, I recently got this interface because of the loopback and onboard DSP features. I was using a Scarlett 2i2, which I will use for another computer. This thing is, this interface when connected to my Mac mini (2020 Intel version) doesn't power off when the Mac goes to sleep. The Scarlett did.
I logged a question to Support and they said "We recommend that you disable any sleep states that your mac is using. Sleep states can causes conflicts with peripheral devices.
If you are not using the Revelator io 24 for an extended period of time then we suggest you disconnect the device."
So it would appear that the unit doesn't sense the sleep and shutdown also. I'm not overly worried about that, however I did mention to them that I was concerned about burn-in on the OLED - and I can already see some of the centre dial when on the gain setting screen. I don't know if it would be permanent yet.
I think it would be a good idea to dim that screen or even provide an option to turn it off to prevent burn-in. That said maybe it isn't an issue?
Someone mentioned in another post that they used a USB strip with switches which I will look at. I had always thought that Audio Interfaces should not be plugged into hubs?
Long winded post here, but I wonder if anyone else has had this concern or issue? and how are they managing it?
Thanks all.
Damien R
Thanks all.
Damien R
