1 post
Please advise when the documentation is available updated with the firmware changes bought forward in V1.31-
Also it would be most helpful, if not essential, to have a block diagram to be able to work out how to use the mic in other situations such as, but not limited to, recording the mic on a channel separate from the mix, recording playback, zoom or OBS (inputs) feeds without the mic by routing without messing with mutes.
I am trying to use with VirtualDJ and every output channel is of a mix and cannot be separated. I would like to record the music mix and the mic channels on separate tracks in Studio One and it's very challenging, and currently I've not found a way.
Thanks for listening.
Cheers
KRK 10 3 monitors. Yamaha O1v, KRK rokit 10 3 monitors. RCF 725-II PA and RCF 325 stage monitors. Turbosound TQ425/455 DP PA.
1 post
