I am entirely unable to access my mic settings through UC without updating the firmware, and entirely unable to update the firmware, I have tried all of the following with no luck: System restarts uninstalling and reinstalling multiple versions of UC, all the way to 2018 versions tried 3 different cables from the mic to the computer tried every possible usb port on my computer unplugging all other peripheral devices removing and uninstalling revelator from the windows device manager mic privacy settings set to allow all Is there really no solution? can presonus make the firmware files available so I can just manually install it if this really can't work |
Hello Isaac,
Were you able to fix the firmware issue? I have the same problem, and I still can't find a solution. Personus support is not very active on this situation. It asks to test with another cable, on another computer, and with other USB hubs. Of course, I have all the money for that and to fix a problem on a new product... Regards. Stephan isaacdesouza wrote |
martinbehrsing wroteHello, I could sove the problem: https://support.presonus.com/hc/en-us/a ... Windows-10 |
