2017 Intel MBP, macOS 11.2.2 - Atom SQ is recognized in UC and works.
M1 Mini - is not seen by UC. |
Crossing fingers...
MBP14" M1Pro 32Gb ram
iMac (27-inch, 2020) Working in DAW: S1 6.5, PT, Logic, Ableton, Reaper. Scoring: Dorico, Finale, Notion, Sibelius Studio 192, RME Fireface, Studio 26C. Atom, Atom SQ, Faderport 8 http://www.fridell.dk |
Universal Control 3.4.2 has been released. Once you grab it, you should see an update available for ATOM SQ, firmware v1.15 which should get you back working with macOS 11.2 (among other improvements). Note that UC may not see the SQ even if you have UC 3.4.2. If it does not, you hold down the Setup button while powering on the SQ (the logo will turn red and the screen will stay on Updating Firmware), then the SQ should be seen in Universal Control. Follow the normal steps after that.
Delete me.
Not super specific in the notes, but I can add more clarity if there are questions.
https://pae-web.presonusmusic.com/downl ... _Notes.pdf |
oscargarza3 wroteNot super specific in the notes, but I can add more clarity if there are questions. Is it worth having a sticky post announcing these firmware updates? Also is this sticky post still an issue from 1967? : viewtopic.php?f=395&t=35014
oscargarza3 wroteUniversal Control 3.4.2 has been released. Note that UC may not see the SQ even if you have UC 3.4.2. If it does not, you hold down the Setup button while powering on the SQ (the logo will turn red and the screen will stay on Updating Firmware), then the SQ should be seen in Universal Control. Follow the normal steps after that. The SQ is now seen by UC 3.4.2 on an M1 Mac Thank you so much. |
PreAl wroteoscargarza3 wroteNot super specific in the notes, but I can add more clarity if there are questions. Was a fine year LOL (and no, it is no longer an issue). I'll talk with the moderators about stickies. |
60s Pop Man wroteoscargarza3 wroteUniversal Control 3.4.2 has been released. Note that UC may not see the SQ even if you have UC 3.4.2. If it does not, you hold down the Setup button while powering on the SQ (the logo will turn red and the screen will stay on Updating Firmware), then the SQ should be seen in Universal Control. Follow the normal steps after that. Thank you all for your patience! |
Hi!!
SQ works now. I just needed to set the inputs/ outputs to "Atom SQ" in Studio One. Thanks!!
oscargarza3 wroteUniversal Control 3.4.2 has been released. Once you grab it, you should see an update available for ATOM SQ, firmware v1.15 which should get you back working with macOS 11.2 (among other improvements). Note that UC may not see the SQ even if you have UC 3.4.2. If it does not, you hold down the Setup button while powering on the SQ (the logo will turn red and the screen will stay on Updating Firmware), then the SQ should be seen in Universal Control. Follow the normal steps after that. Thanks for keeping us up-to-date and the update itself! |
