37 postsPage 2 of 2
1, 2
2017 Intel MBP, macOS 11.2.2 - Atom SQ is recognized in UC and works. :thumbup:
M1 Mini - is not seen by UC.
M1 Mini (16GB RAM, 1TB SSD) / macOS 13.6 / S1 6.5 Pro / Melodyne 5 Editor / Notion 6.8.4 / Faderport 8, Eris 5
by rickbaumhauer on Thu Mar 11, 2021 3:06 pm
I've boxed up the Atom SQ - no reason to have it out until the issue is fixed - but I'll hold off on returning it to see if the fix comes before I have to return it. I'll be testing another option in the meantime, and will compare to the Atom SQ if the new firmware comes out in time to test.
by frankschbel1 on Fri Mar 19, 2021 7:35 am
Any news?
Studio One 6 Prof. | Mac-Studio M1 Ultra 64 GB | Quantum 2626 | SSL-UF8 | SSL-UC-1 | SSL-UF1 | Roland A-88 | Atom SQ
by oscargarza3 on Fri Mar 19, 2021 7:53 am
So long as there are no changes, which is always possible, should be something next week.
by pellefridell on Tue Mar 23, 2021 3:21 am
Crossing fingers... :-)
MBP14" M1Pro 32Gb ram
iMac (27-inch, 2020)
Working in
DAW: S1 6.5, PT, Logic, Ableton, Reaper.
Scoring: Dorico, Finale, Notion, Sibelius
Studio 192, RME Fireface, Studio 26C.
Atom, Atom SQ, Faderport 8
http://www.fridell.dk
by oscargarza3 on Tue Mar 23, 2021 9:20 am
Universal Control 3.4.2 has been released. Once you grab it, you should see an update available for ATOM SQ, firmware v1.15 which should get you back working with macOS 11.2 (among other improvements). Note that UC may not see the SQ even if you have UC 3.4.2. If it does not, you hold down the Setup button while powering on the SQ (the logo will turn red and the screen will stay on Updating Firmware), then the SQ should be seen in Universal Control. Follow the normal steps after that.
by PreAl on Tue Mar 23, 2021 9:35 am
Delete me.
by robertgray3 on Tue Mar 23, 2021 10:32 am
oscargarza3 wroteworking with macOS 11.2 (among other improvements).
Are there any release notes? Curious what improvements to look for and try out.
Mac OS X Catalina 10.15.7
Mac Pro 6.1
3 GHz 8-Core Intel Xeon E5
32 GB 1066 MHz DDR3
Dual AMD FirePro D500 3072 MB
Quantum 2
by oscargarza3 on Tue Mar 23, 2021 10:34 am
Not super specific in the notes, but I can add more clarity if there are questions.
https://pae-web.presonusmusic.com/downl ... _Notes.pdf
by PreAl on Tue Mar 23, 2021 10:39 am
oscargarza3 wroteNot super specific in the notes, but I can add more clarity if there are questions.
Is it worth having a sticky post announcing these firmware updates?
Also is this sticky post still an issue from 1967? :lol: :
viewtopic.php?f=395&t=35014
by 60s Pop Man on Tue Mar 23, 2021 11:03 am
oscargarza3 wroteUniversal Control 3.4.2 has been released. Note that UC may not see the SQ even if you have UC 3.4.2. If it does not, you hold down the Setup button while powering on the SQ (the logo will turn red and the screen will stay on Updating Firmware), then the SQ should be seen in Universal Control. Follow the normal steps after that.
:arrow: The SQ is now seen by UC 3.4.2 on an M1 Mac :+1 :punk:
Thank you so much.
by oscargarza3 on Tue Mar 23, 2021 11:09 am
Was a fine year LOL (and no, it is no longer an issue). I'll talk with the moderators about stickies.
by oscargarza3 on Tue Mar 23, 2021 11:10 am
Thank you so much.
Thank you all for your patience!
by frankschbel1 on Tue Mar 23, 2021 1:36 pm
And now.... It works :thumbup:
by jrgenmessing on Wed Mar 24, 2021 12:49 am
Today, 24th of March, PreSonus made a firmware update available for the Atom SQ, version 1.15. This solves the connection problem for me (macOS 11.2.3, Intel).
by pellefridell on Wed Mar 24, 2021 5:58 am
Hi!!
SQ works now.
I just needed to set the inputs/ outputs to "Atom SQ" in Studio One.
Thanks!!
Working in
by horusandreph on Thu Mar 25, 2021 11:40 pm
oscargarza3 wroteUniversal Control 3.4.2 has been released. Once you grab it, you should see an update available for ATOM SQ, firmware v1.15 which should get you back working with macOS 11.2 (among other improvements). Note that UC may not see the SQ even if you have UC 3.4.2. If it does not, you hold down the Setup button while powering on the SQ (the logo will turn red and the screen will stay on Updating Firmware), then the SQ should be seen in Universal Control. Follow the normal steps after that.
Thanks for keeping us up-to-date and the update itself! :)
37 postsPage 2 of 2
1, 2
