Is anyone unplugging the SQ when it’s not in use? Any reason to do so since it stays semi-powered?
Windows 10 64-bit | Studio One Pro (newest update at time of posting the message) | 8 cores | 16GB Ram | Focusrite Scarlett 18i20 interface (2nd Gen) | Presonus Eris E44 Monitors | Atom SQ | Roland VG-99 | EZBass, EZKeys 2, Superior Drummer 3, EZ Drummer 3, various other virtual instruments | a surfeit of guitars and third-party plugins
Newest release, using Studio One Other music created in Studio One |
Check this thread.
viewtopic.php?p=249944#p249944
PreAl wroteCheck this thread. Thanks, I didn't think to look in the other Atom thread. Only one post about the wisdom of disconnecting the unit every day, but a pretty good piece of advice and several good links to solutions. Thanks again.
SQ powers down when you shut your computer down. (Unlike ATOM) Its only a matter of whether you want to see it lit up while your computer is on and working either on something else or a Studio One project.
But you can press the Setup button very top right hand corner and select the LEDS switch and reduce them right down (or completely OFF) if the pads are catching your eye while not using or using Studio One for example. SQ is generally is much more friendly that way. I would not be plugging and unplugging all the time. You will wear out either the USB socket on your computer or the socket on the rear panel of SQ (which is smaller and more vulnerable to constant disconnection) A USB power switch plus data connection would be a good alternative.
I've had my SQ plugged into this for it's entire time with me so far, and the power button next to the USB port works great.
https://www.amazon.com/gp/product/B07G8 ... UTF8&psc=1 |
