Hi all.
I am about to press go on an SQ but have held back because the specs state the SQ needs S15 to integrate properly. I alreeady own S14 Pro and feel a tad irritated that the SQ will not fully work with my copy. Does anyone know what I will be missing when I run an SQ on S14 pro please?? I appreciate the SQ comes with S15 Artist adition but I use scratch pads a lot and dont want to lose them. I feel getting Artist is fantastic for new S1 users but what about us already loyal customers. I own and have owned a load or presonus products over the years and will most likely be choosing presonus for my next monitor purchase in a month or so. |
I did some testing with the Atom SQ and Version 4.6 and it does not work at all. You can't even set it up as generic MIDI as far as I can see. Not even the MIDI learn option works. Wish I had better news.
Johnny
johnny
www.hst-homestudiotrainer.com Main Site https://www.hst-homestudiotrainer.com/ Pivotshare Subscription Site https://homestudiotrainer.pivotshare.com YouTube Channel https://www.youtube.com/homestudiotra... |
The System Requirements for ATOM SQ do say Studio One V5 or higher.
Search the STUDIO ONE 4 ONLINE MANUAL. Access your MY.PRESONUS account. OVERVIEW of how to get your issue fixed or the steps to create a SUPPORT TICKET. Needs to include: 1) One Sentence Description 2) Expected Results 3) Actual Results 4) Steps to Reproduce. Specs i5-2500K 3.5 Ghz-8 Gb RAM-Win 7 64 bit - ATI Radeon HD6900 Series - RME HDSP9632 - Midex 8 Midi interface - Faderport 2/8 - Atom Pad- iMac 2.5Ghz Core i5 - High Sierra 10.13.6 - Focusrite Clarett 2 Pre & Scarlett 18i20. Studio One V5.1 (Mac), Notion 6.7, Ableton Live 10 Suite, LaunchPad Pro |
Thanks for your replies.
I have to say I think it stinks. Of course I fully intend updating to five at some point but I dont like being pressured to do so, especially when my studio is getting ever fuller of Presonus products. I doubt there is any reason Atom SQ couldnt have been made play well with S1 4 pro. I think Presonus should offer a larger upgrade discount to Studio One 4 pro users who buy Atom sq |
Presonus is not pressuring anyone to do anything.
Bbd
Please add your specs to your SIGNATURE. Search the STUDIO ONE 5 ONLINE MANUAL. Access your MY.PRESONUS account. OVERVIEW of how to get your issue fixed or the steps to create a SUPPORT TICKET. Needs to include: 1) One Sentence Description 2) Expected Results 3) Actual Results 4) Steps to Reproduce. OS: Win 10 x64 Home, Studio One Pro 5.x, Notion 6, Series III 24, Studio 192, Haswell CPU: i7 4790k @ 4.4GHz, RAM: 16GB, Faderport 8/16, Central Station +, PreSonus Sceptre S6, Eris 3.5, Temblor 10, ATOM, ATOM SQ |
The ATOM SQ absolutely works as a standard MIDI controller in Studio One 4 (or even earlier versions). Set it up as a "New Keyboard" and make sure that the send and receive ports are set to ATOM SQ. You won't get all the cool, direct integration that you get in Studio One 5+, but you can map out the device to key commands and plugin parameters. Plus, the ATOM SQ has built in Scale modes that you can use in Studio One (or any application) as well. If you wanted to get fancy, you could also put ATOM SQ into MCU control mode, set up a Mackie>"Control" in Studio One and set the ports to ATOM SQ Control or MIDI2 on Windows. This way, the transport is automapped (for the most part) and you also get commands like Solo, Mute, etc., from ATOM SQ. You will also still need to have the "New Keyboard" setup as described above in addition to MCU.
oscargarza3 wroteThe ATOM SQ absolutely works as a standard MIDI controller in Studio One 4 (or even earlier versions). Set it up as a "New Keyboard" and make sure that the send and receive ports are set to ATOM SQ. You won't get all the cool, direct integration that you get in Studio One 5+, but you can map out the device to key commands and plugin parameters. Plus, the ATOM SQ has built in Scale modes that you can use in Studio One (or any application) as well. If you wanted to get fancy, you could also put ATOM SQ into MCU control mode, set up a Mackie>"Control" in Studio One and set the ports to ATOM SQ Control or MIDI2 on Windows. This way, the transport is automapped (for the most part) and you also get commands like Solo, Mute, etc., from ATOM SQ. You will also still need to have the "New Keyboard" setup as described above in addition to MCU. I tried this several times and it did not work here. I'm not sure what you did differently but I can say so far no go on Studio One 4. I will look into the other modes on the Atom and see what works. I appreciate your info ![]()
johnny
