My SQ arrived today.I've read the manual and I'm trying to duplicate the basic 16 steps to make them copy my original 16, turn them into 32/64 etc, but there seems to be no sort of function for that,from what I can see.
What makes no sense,is if I start off with a basic 16 steps, and I want to extend that to 32,64,or 128.. The only way I can see to do this, is to change the steps manually , but that doesn't duplicate the previous steps.. Also there doesn't appear to be any visual representation on the controller..For example, how do we follow the steps on the hardware, as we go past 16 steps? Anyone figured this out yet? Super lost with it ;( Other then this, the unit is built fine pads and velocity feel fine,despite what I've read. The knobs don't at all show values ,so you have to move them to get any sort of visual readout.. The browser immediately closes once you load a kit, that's aggravating hopefully, that can be changed.. When loading different sounds, I don't want that constant battle to have to open a browser, it should be set to autoload upon scrolling as an option at the very least. My main issue,is there's no real good documentation on how to perform the most basic functions such as duplicate steps on the step sequencer, which is frustrating.
Cpu: i9 10900k Desktop Win10 + 2015 Mac Pro i7@4.3ghz/SSDs
Tools: Slate VMS/Apollo X6/Antelope Audio Discrete 8 Synergy Core/Heritage Audio R.A.M.2000/API Lunchbox 6/Dyn Audio Bm5a MK2+Adam Audio Kurzweil Forte 88/Virus TI2 61/Behringer DeepMind 12D/Powercore Virus B/Akai MPC X/Komplete Kontrol MK2/Samples/Vst |
Anyone find a way to duplicate steps from the SQ?
Seems counterintuitive to have to do this in the software. Is this Step Seq with the Sq, just not ready yet? Thanks in advance if you can help ![]() ![]()
You can make a patter 64 steps long (4 bars) The left/right arrows (under the main display) is how you select each group of 16. When you do this note the grey line above in the editor display in Studio One will change from 1-16 to 17-32 etc..This is how you still see each group of 16 steps in TR808 programming mode.
But what I want to ask you John is do you want to say start with a pattern that is 1 bar long (eg 16 steps) Create a bass drum pattern say and then duplicate the bass drum part say 4 times so the pattern is now 64 steps long. And then you want to add other sounds in etc.. I have worked this out now. What you do is start by creating a pattern 1 bar long. eg 16 steps. Add in say your kick part that you know you want to repeat 4 times. You can use TR808 style programming to do it. Select the sound in the top row and place the hits using the bottom row of SQ pads. Stop the DAW. Select the pattern. Press D on your keyboard 3 times and it is now 4 patterns the same. Press G to merge them all. The pattern is now converted to a part. Then select this part and right click, go to Instrument parts and select Convert Part to pattern again. You now have a pattern 64 steps long (eg 4 bars) You can go back to TR808 style programming again and use the left/right arrows mentioned above to select the correct group of 16 to add in the extra sounds.
Search the STUDIO ONE 4 ONLINE MANUAL. Access your MY.PRESONUS account. OVERVIEW of how to get your issue fixed or the steps to create a SUPPORT TICKET. Needs to include: 1) One Sentence Description 2) Expected Results 3) Actual Results 4) Steps to Reproduce. Specs i5-2500K 3.5 Ghz-8 Gb RAM-Win 7 64 bit - ATI Radeon HD6900 Series - RME HDSP9632 - Midex 8 Midi interface - Faderport 2/8 - Atom Pad- iMac 2.5Ghz Core i5 - High Sierra 10.13.6 - Focusrite Clarett 2 Pre & Scarlett 18i20. Studio One V5.2 (Mac), Notion 6.7, Ableton Live 11 Suite, LaunchPad Pro |
You are AWESOME!! I was starting to think it wasn't possible, thanks so much!!!
Yes I know LOL!
![]() Keep asking for things though and when you hit a road block put it up here. Its either possible or we can get new features added in.
Videos on YouTube are available. Recommended.
Studio One Pro 5, Faderport Classic (1.45), Atom Pad, Atom SQ, Presonus Studio 26c, Focusrite Saffire Pro 40, Maschine Studio, Octapad SPD-30, Roland A300, Windows 10 Pro 64 bit, also running it on Mac OS Catalina via dual boot (experimental).
Intel i9 9900K, 32GB RAM, EVGA Geforce 1070 (Nvidia drivers). Dell Inspiron 7591 (2 in 1) 16Gb. |
I've tried finding youtube video's that went into detail about the step sequencer, but there isn't anything other then some basic explanations in them. Thanks jemusic for breaking that down to me. I think Presonus should get some better documentation on this, thanks to jemusic and (themusik johnnys) channel.
jonhamilton2 wroteI've tried finding youtube video's that went into detail about the step sequencer, but there isn't anything other then some basic explanations in them. Thanks jemusic for breaking that down to me. I think Presonus should get some better documentation on this, thanks to jemusic and (themusik johnnys) channel. You didn't look hard enough... https://www.youtube.com/playlist?list=P ... X9HK73SBWx
The Sequencer Deep Dive is a good video. And there is an easier way to duplicate a kick part that might start out as a one bar pattern and you may want it to end up over a 4 bar pattern etc..
Thanks!
