In this video,Around 10:10 https://www.youtube.com/watch?v=45fs0eNOTUs Oscar goes over Chord mode working with the SQ, again I'm not finding any detailed information regarding this question I have. And that's, Is it possible to substitute Chorder for a more complete Chord plugin, such as Plugin Boutiques Scaler 2? thnx
Cpu: i9 10900k Desktop Win10 + 2015 Mac Pro i7@4.3ghz/SSDs
Tools: Slate VMS/Apollo X6/Antelope Audio Discrete 8 Synergy Core/Heritage Audio R.A.M.2000/API Lunchbox 6/Dyn Audio Bm5a MK2+Adam Audio Kurzweil Forte 88/Virus TI2 61/Behringer DeepMind 12D/Powercore Virus B/Akai MPC X/Komplete Kontrol MK2/Samples/Vst |
Yes, but not in quite the same way as using Chorder itself. Chorder is a "Note FX" device (one of four different ones) that is designed be put in a special Note FX insert rack that changes the incoming MIDI on its way from the DAW's Midi Inputs to the Instrument on that track/channel.
Scaler2 is an instrument, not a "Note FX device". So we have to play a simple trick to make your incoming MIDI first go through Scaler2, be transformed inside of Scaler2, and then be forwarded to a different instrument sitting on a different track/channel than Scaler2 itself.
Note that the recorded notes on the MaiTai track will all be lagging behind the recorded notes on the Scaler 2 track. Even if you disable the input quantize button (IQ) while recording. This is just a result of several factors related to latency and block size. There's no way to keep them perfectly in sync. Just be prepared to clean up and quantize and adjust when you are somehow recording the MIDI output of Scaler2 onto another track. IMO the best overall approach to recording the transformed output from Scaler 2 is to turn monitoring ON for BOTH tracks, but arm only the MaiTai track for recording. This will be less confusing in the results and you can use LLM during recording and/or some post-recording quantizing and cleanup after you're done with your takes. |
That makes sense. Thanks again.
robertgray3 wroteYou mean you want the button for "Add Chorder NoteFX" on the Atom SQ interface to launch a plugin of your choice? Chorder is a NoteFX, not a VSTi or AUi plugin. Sorry I should have been more specific.. What I was wondering is if it's possible, to browse our own plugins, then load them from the controller.. In the case of Scaler or our VST2/VST3 plugins in general, is it as easy as browsing and loading them from the controller as well? Thanks for pointing out the fact Chorder is a Note FX.. (midi plugin) I rarely use it, n forgot. Thanks
Mine will be here tomorrow, so I'll just figure it out then
