Still waiting for my unit to arrive - Just curious if anyone has tested to see if it's possible to assign the start and end points of a sample using the different knobs on the SQ? Is the SQ by default set up in this manner, or do you have to manually do it? thnx
Cpu: i9 10900k Desktop Win10 + 2015 Mac Pro i7@4.3ghz/SSDs
Tools: Slate VMS/Apollo X6/Antelope Audio Discrete 8 Synergy Core/Heritage Audio R.A.M.2000/API Lunchbox 6/Dyn Audio Bm5a MK2+Adam Audio Kurzweil Forte 88/Virus TI2 61/Behringer DeepMind 12D/Powercore Virus B/Akai MPC X/Komplete Kontrol MK2/Samples/Vst |
I would download the manual and read it.. doesn't take very long to go through..
https://www.presonus.com/products/ATOM-SQ/downloads
Intel i9 9900K, 32GB RAM, EVGA Geforce 1070 (Nvidia drivers). Dell Inspiron 7591 (2 in 1) 16Gb. |
I have been trying to do this but have not been able to. The sample Start and End points are not part of the parameters that can be mapped to the knobs. I can get almost everything else within Impact to be mapped but this. Any control on the right hand side effecting the sound can be mapped.
Sample Start and End points are inside the upper window and may not be able to be mapped. But you never know either. I will keep researching this. If not it would be a very logical thing to do. So we might make it a FR.
Search the STUDIO ONE 4 ONLINE MANUAL. Access your MY.PRESONUS account. OVERVIEW of how to get your issue fixed or the steps to create a SUPPORT TICKET. Needs to include: 1) One Sentence Description 2) Expected Results 3) Actual Results 4) Steps to Reproduce. Specs i5-2500K 3.5 Ghz-8 Gb RAM-Win 7 64 bit - ATI Radeon HD6900 Series - RME HDSP9632 - Midex 8 Midi interface - Faderport 2/8 - Atom Pad- iMac 2.5Ghz Core i5 - High Sierra 10.13.6 - Focusrite Clarett 2 Pre & Scarlett 18i20. Studio One V5.1 (Mac), Notion 6.7, Ableton Live 10 Suite, LaunchPad Pro |
Thanks guys, yes I have downloaded the manual, and wasn't able to find it, thanks for the replies.
Jemusic wroteI have been trying to do this but have not been able to. The sample Start and End points are not part of the keyboard commands therefore they may not be able to be mapped to the knobs. I can get almost everything else within Impact to be mapped but this. Any control on the right hand side effecting the sound can be mapped. Thanks for confirming Jemusic
You can't actually set the start and end points with knobs OR automation lanes, because those parameters are not exposed to automation.
But you CAN automate and assign the SQ knobs to the Start OFFSET and the End OFFSET of whichever sample is currently in focus. First, make sure the Impact XT track is being monitored so that the SQ is controlling it. Then open the Track Inspector for the Arranger track that has that instance of XT on it. Then in the middle channel section of the Inspector, click the little knob-shaped Channel Editor button to bring up the macro knobs for that channel. Then click the wrench in the channel editor, and assign Impact > Focus > Sample Start Offset (Focus) to one of the listed Knobs on the left. Do this again and assign Impact > Focus > Sample End Offset (Focus) to one of the other listed Knobs. Click the wrench again to go back to the main 8 macro knobs in the Channel Editor. Now here's the really really IMPORTANT part
So: now do this. Make sure the Channel Editor is in focus. You can place it side by side with the XT instrument editor itself. You can always tell which of those two editors are in focus, because the in-focus one is indicated by a bright yellow highlight in the upper right where it says ATOM SQ. Now tap ANY pad on the SQ and twiddle those two knobs while LISTENING to the sound of the focused sample on that pad. You won't see any visual feedback on the sample waveform itself. But if you look at the two Offsets values over on the right side of the XT instrument, you'll see that the SQ knobs are indeed changing the start and end offset. Now tap a different pad while you twiddle those same two SQ knobs. You'll see and hear the offset values change accordingly for this other pad. Finally, click somewhere in the XT editor window and watch it's ATOM SQ indicator light up yellow. Now tap any pad and twiddle those same SQ knobs and you'll see/hear the hardcoded Pitch/Filter/Gain parameters changing, while nothing changes over in the Channel Editor. Yes, the SQ is really nice this way. ![]() |
Thanks Shannon. I think I may have had it working too at some point but I was not playing pads, I was watching the sample markers all the time and not even the sample start/end settings either.
Glad to see that it can be done but its a slight workaround though. Seeing the sample start and end points visually move on the sample itself would have been more ideal but at least hearing it is OK. But moving the markers manually is the way to do it visually. Its also very cool you can control up to 16 things with the 8 knobs too just by switching focus. Did not know that either.
Jemusic wroteIts also very cool you can control up to 16 things with the 8 knobs too just by switching focus. Did not know that either. Yeah, it was a nice surprise compared to how the Faderport 8 works. The FP8 is great for plugin control because of the 8 banks of 8 faders for each individual plugin in the Edit Plugins mode. But for the Instrument Editor, your only option is to use the FP8's Macro mode, which is linked to the the 8 knobs in the Channel Editor. So you effectively have control over only 8 instrument parameters instead of the 16 parameters you can achieve on the SQ. It's a shame that Presonus still bursts out the parameters associated with a macro knob in the Channel Editor when you try to automate the macro knob, into a separate automation lane for each parameter. For the way I work, this makes me avoid Macro knobs altogether. What's the point of having multiple parameters on a single macro knob (and the ability to set the start/end points and response curve of each parameter range) if you can't actually just automate the knob itself with a single automation lane? Every other DAW I've ever used does this, and it's what makes macro knobs so powerful in those DAWs. |
Thanks shannongreywalker for the detailed replies.
