Dear all
Just received my SQ, so far so very good.... Today I wanted to map my knobs to the Analog Lab of the Vcollection 8. I follow the traditional procedure, the buttons are well mapped... but the sound does not change. It look crazy : when I move the Atom knob I see the virtual knob of tone moving but the sound does not change. When change the knob on the vst itself it work ?????!!!!!!! I'm really lost on that case... I do not have this behavior on other plugins Any clue ? |
Make sure the Atom SQ is listed and highlighted in orange at the top right of the Analog Lab window.
Toronto, Canada
Project engineer by day, sound connoisseur by night. Main Rig: Windows 11 (21H2) 64-bit, Ryzen 3900x, 32GB RAM, RTX 2060, dual 4K Monitors Presonus 192, Faderport v2, Atom SQ, Akai Advance 49, Keystation 61 mk3, 2x Behringer X-Touch Mini + way too many synths. Mobile Rig: MBP M1/16GB, Atom SQ, IOstation |
Thanks for answer but It is highlighted and Active
I think I will have to route my question on the Arturia forums because it's the only vst that has the strange behavior. Mapping is working. I see the knobs of the atom active , the mapping works AND the button in Analog is moving... but no sound change !! ( unless I move the analog lab button with the mouse )... arggghhhh |
philippebardyn wroteThanks for answer but It is highlighted and Active Have you found a solution for this issue. I have the same problem. Thanks |
Sorry for the late reply.. no still the same problem with latest version of studio one and analog lab… buttons are moving accordingly but sound does not change ..
The VST 2.4 works as expected in Reason 12. BTW, here is a link to the other thread in the S1 forum: viewtopic.php?f=151&t=48907
So this thread looks to be pretty dead, but an update is still in order.
The VST 2.4 has exactly the same issue as the VST 3. This was confirmed in the other thread AND by Presonus. Reason 12 and standalone do NOT have the same issue, they work fine (VST 2.4 in Reason. ) Arturia support has finally answered my ticket. We'll see how that goes. Like I said in the other thread if you have this issue, please open a ticket with Arturia or even Presonus, or both |
Annnnnnnnnnnnd, I'm out. I've informed Arturia/Presonus of the problems, Presonus CAN reproduce it, Arturia CANNOT.
I've spent WAY too much time on this, and I almost never use that VI anyways I've given Arturia the name of TS from Presonus, and Presonus the name from Arturia TS. I've wasted too much time on this. |
