Is anyone unplugging the SQ when it’s not in use? Any reason to do so since it stays semi-powered?
Windows 10 64-bit | Studio One Pro (newest update at time of posting the message) | 8 cores | 16GB Ram | Focusrite Scarlett 18i20 interface (2nd Gen) | Presonus Eris E44 Monitors | Atom SQ
Newest release, using Studio One! Other music created in Studio One |
Check this thread.
viewtopic.php?p=249944#p249944
Studio One Pro 5, Faderport Classic (1.45), Atom Pad, Atom SQ, Presonus Studio 26c, Focusrite Saffire Pro 40, Maschine Studio, Octapad SPD-30, Roland A300, Windows 10 Pro 64 bit, also running it on Mac OS Catalina via dual boot (experimental).
Intel i9 9900K, 32GB RAM, EVGA Geforce 1070 (Nvidia drivers). Dell Inspiron 7591 (2 in 1) 16Gb. |
PreAl wroteCheck this thread. Thanks, I didn't think to look in the other Atom thread. Only one post about the wisdom of disconnecting the unit every day, but a pretty good piece of advice and several good links to solutions. Thanks again.
SQ powers down when you shut your computer down. (Unlike ATOM) Its only a matter of whether you want to see it lit up while your computer is on and working either on something else or a Studio One project.
But you can press the Setup button very top right hand corner and select the LEDS switch and reduce them right down (or completely OFF) if the pads are catching your eye while not using or using Studio One for example. SQ is generally is much more friendly that way. I would not be plugging and unplugging all the time. You will wear out either the USB socket on your computer or the socket on the rear panel of SQ (which is smaller and more vulnerable to constant disconnection) A USB power switch plus data connection would be a good alternative.
Search the STUDIO ONE 4 ONLINE MANUAL. Access your MY.PRESONUS account. OVERVIEW of how to get your issue fixed or the steps to create a SUPPORT TICKET. Needs to include: 1) One Sentence Description 2) Expected Results 3) Actual Results 4) Steps to Reproduce. Specs i5-2500K 3.5 Ghz-8 Gb RAM-Win 7 64 bit - ATI Radeon HD6900 Series - RME HDSP9632 - Midex 8 Midi interface - Faderport 2/8 - Atom Pad- iMac 2.5Ghz Core i5 - High Sierra 10.13.6 - Focusrite Clarett 2 Pre & Scarlett 18i20. Studio One V5.1 (Mac), Notion 6.7, Ableton Live 10 Suite, LaunchPad Pro |
I've had my SQ plugged into this for it's entire time with me so far, and the power button next to the USB port works great.
https://www.amazon.com/gp/product/B07G8 ... UTF8&psc=1 |
