It is stated that for the motorized fader to work, this device needs to be connected with a power adapter. So can it be used without a power adapter as well? Will the fader still work in Studio as a regular, manually controlled fader with soft pick-up?
Where did you see that information stated?
I have one of these and it won't power on without the external power supply adapter. Here's the required tech specs per PreSonus...
Download the SO 6 PDF MANUAL. Access your MY.PRESONUS account. OVERVIEW of how to get your issue fixed or the steps to create a SUPPORT TICKET. Needs to include: 1) Subject 2) Description 3) Country 4) Product 5) OS 6) Audio Software Windows 11 Pro 64-bit (23H2), Studio One 6.6.1 Professional | Notion 6.8.2 | Universal Control v4.3.1.100005 Intel NUC 13 (Intel i5-1340P, Intel Iris Xe Graphics, 32GB RAM, 2TB SSD, Revelator, SIII 32 |
Trucky wroteWhere did you see that information stated? Thanks for the info! I probably saw the power specifications for the Faderport V2 somewhere and erroneously assumed the ioStation would work the same way. |
SwitchBack wroteMaybe stating the obvious but it doesn't have to be an adapter per se, it can be a battery too. 12V power tool batteries are compact and can have quite a bit of stamina too That's a good suggestion but I'm looking to make my setup both more mobile and more lean. This would preferably not include an extra battery pack |
