SOLVED - ioSTATION 24c need to restart
Posted: Thu Apr 29, 2021 10:51 am
by uqfydlnk
when i change the audio driver to my other sound card and rechoose iostation back, it doesnt recognize the iostation. this happens when using windows and change the soundcard to another one and also happens in the Studio One DAW. i always have to turn off and back on the iostation to be recognized again. i couldnt find a solution and tired of turning off and on again and again. i am using the latest firmware and the latest drivers for iostation. any solution for this ?
SOLVED - Re: ioSTATION 24c need to restart
Posted: Fri Apr 30, 2021 10:13 am
by Trucky
Here's what works for me...
Uncheck "Exclusive Mode" (for both Playback & Record) in Properties for all your audio devices.
Posted: Fri Apr 30, 2021 10:35 am
by uqfydlnk
thanks for the reply, but i found the problem. i changed the usb slot that i connect the unit to my computer. dang, problem solved. it was probably a compatibility issue. now it works as it should.
