I do not know if this is the proper area in the forum, but I'm a Studio one 5 user with the IOstation and I've noted some issues:
1. When an instrument window is open, clicking on MUTE, will MUTE the track BUT will not be displayed as MUTE (Red M). It's manageable, but does provide some surprise when there's a lot of track and you can't quickly identified which one was muted.
2. When navigating within a folder, the main knob "push" does not select. So I can navigate between presets, but they don't get selected unless I do actually click on it with mouse or keyboard at that point. That one is quite frustrating.
3. When Automating a parameter in a VST, for example the cutoff in Mai Tai, with LINK on, I go on the knob, if I click on an automation mode "write", "Latch", etc... on the IOstation, nothing happen. I have to manually select the mode with my mouse. That one is quite an issue as you're loosing a big part of what's making the IOstation so good for editing on the spot.
I'm using studio 5.2 and have all the latest firmware updates on the IOStation.
Best regards !
by Bbd on Tue Mar 30, 2021 1:02 pm
David,
Please open a Support ticket for your findings to they can report this.
Also, please list your specs.
Thanks.
Bbd
by davidwasselin on Thu Apr 01, 2021 7:54 am
Will do !
