Longtime user of iConnectAUDIO2+ which PreSonus just stopped supporting properly with their buggy Auracle software. Finally got to the stage where I could use the microphone fine but couldn't get sound to output (in Windows). Decided to upgrade to ioStation24c (as I use StudioOne quite a bit and Notion and wanted to stay in the ecosystem), thinking that newer hardware would be better supported. Boy was I wrong, and this thread shows that PreSonus clearly don't listen or care, as it's July and I just had the same problem, with no response from them yet...
The inputs and outputs work fine in StudioOne, and I can use the output (headphones) from windows, but I can no longer get the input via windows. The "Mic/Inst/Line In 1/2" and "Virtual 1/2" devices show no levels, so clearly there's a problem. That's why you can't use the mic in Zoom/Teams/etc. too. |
Potential fix:
Search for "Fix audio" in the Windows taskbar, you will see an option for "Find and fix problems with playing sound" this is the recording troubleshooter. Run through this. In my case it said the Default Format wasn't set correctly, which is bizarre because it definitely was set to "2 channel, 24 bit 48000 Hz (Studio Quality)", however after applying the fix, I then got sound through. |
On Windows, the audio format settings are a bit of a juggling act.
Sometimes just switching from the windows menu to 44.1khz and back to 48khz will solve issues.
Toronto, Canada
Welcome to the Forum!
Does Universal Control detect it correctly and if so, what firmware version are you running? Please add your system specs to your signature (see link in my signature below) with as much details as possible as it helps in responding to your issue.
