Toggle mode on transport panel?
Posted: Fri Jan 27, 2023 5:50 am
by dallon426
How can I change all of the buttons to go from toggle to single press?
For example I just want play to be a single press not a toggle
I have seen it work in Logic which is what I am using.
https://youtu.be/wp4D84xmEHshttps://www.youtube.com/watch?v=xvD0P5hzI4o
Re: Toggle mode on transport panel?
Posted: Mon Jan 30, 2023 6:44 am
by dallon426
If this is not possible, it shiould be fixed in an update.
Posted: Mon Jan 30, 2023 6:09 pm
by reggie1979beatz
Just a PSA, if you want an update, you have two options: Start a "feature request" and/or try and open a support ticket. Good luck either way, the few things I've griped about have largely gone by the wayside.
It's true that these are EXCELLENT controllers (and I have both, and they mostly serve me well) but they could still use some love.
This section of the forum is mostly dead as a doorknob. Not much going on there, especially from devs.
Posted: Tue Jan 31, 2023 1:06 am
by dallon426
Pretty lame that they do not update it
Posted: Tue Jan 31, 2023 11:42 pm
by dallon426
So, if I hit the stop button (1 time) controller 111 it has two velocities 127 and then 0
If I hit play and other various buttons I have to hit them (two times) to get the two velocities
if I hit the button (one time) only one velocity appears 127
Hit it again and it goes to 0
Posted: Tue Jan 31, 2023 11:49 pm
by dallon426
What should happen is that we can choose how each button reacts on the atom. If I want it to toggle or to be a single button press. That is the issue because in third party softwares it does not work fluidly.
I have uploaded the midi monitor picture to demonstrate this.
The buttons that work the way I would like are
Stop
Select
Right
Left
Down
Up
All the other buttons are toggle and this is annoying when opening windows
Play
Record
Click
Zoom
Setup
Set Loop
Editor
Nudge
Show/hide
Preset
Does this make sense what I am saying? I hope you understand. The controller is good, but these are some issues that I hope can be worked out. Thanks
Posted: Wed Feb 01, 2023 11:08 am
by Robert Johnson III
In logic you can delete the last two digits in expert view (learn function) Then it behaves als a single press button
