I'm wondering if any of you use Atom Pad together with Atom SQ. . I'm using NI Maschine as a midi controller and want to switch to Atom SQ. Main reason to switch to Atom SQ is ability to work with step sequencer, but I would also be able to use fingers for program drums. My question is: Is Atom SQ enough for finger drumming? If is not enough, should I keep my NI Maschine or maybe there are some additional benefits of using Atom SQ togeter with Atom Pad? Thanks! |
Finger drumming on the SQ pad layout will not be nearly as ergonomic and simple as finger drumming on a 4x4 pad layout like Maschine, the original ATOM, etc.
The SQ is great for a variety of reasons, but finger drumming isn't one of them. It's perfectly adequate for blapping in bits and pieces of a drum pattern while you're overdub recording, but it won't make for easy live performance finger drumming. |
When i added atom sq into my system i lost all my atom created songs connections. so i had beats there but not the ones i used.... inherently ruining all of my work. now atom no longer switches pads between different presets it just holds the first preset. Cool ideas with a wonky approach. Can we please get a Default to impact only option for the atom and a default to mojito to atom sq option. so on and so forth so this software works more fluidly ? At this point i'm in Cubase starting over because all my cool looking atom stuff is in a box
Both my Atom and Atom SQ are working as advertised, I have no issues whatsoever ?
Newest Drivers :
https://www.presonus.com/products/ATOM-SQ/downloads
