How do you change the "root note" on the ATOM?
Posted: Thu May 23, 2019 10:59 am
by chrisharwood
Seems the default is from C to C...along with the transpose up/down pads. How can I change it to G to G, for instance?.... without complicated re-mapping, etc?
Re: How do you change the "root note" on the ATOM?
Posted: Thu May 23, 2019 2:44 pm
by Jemusic
Simple. Select the track you have ATOM on and open the inspector. Use the transpose function. e.g. if you set that to 2 the ATOM pads now play from D to D
Posted: Thu May 23, 2019 5:04 pm
by chrisharwood
yes that works, but only transposes the track. It does not change what notes are actually recorded. I guess you could just bounce the track afterwards...?
Posted: Sat May 25, 2019 5:02 pm
by Jemusic
Or once you are happy with all the midi data, you then edit the midi and put it all up 2 semitones permanently and then remove the transpose option in the inspector.
I agree though a nice feature might be to be able to transpose directly from ATOM and then the track would be recording the right data straight away.
Posted: Mon May 27, 2019 2:40 pm
by chrisharwood
yes...that and/or being able to transpose up in increments vs just octaves. Thx for the great answers.
Posted: Thu Aug 01, 2019 9:11 pm
by torbjrnbergman
chrisharwood wroteSeems the default is from C to C...along with the transpose up/down pads. How can I change it to G to G, for instance?.... without complicated re-mapping, etc?
It's a mystery to me why this setting is not standard on all drum pads !
When I receive my Atom the first thing I am going to try is this :
https://www.codefn42.com/notemapper/index.html
Posted: Fri Aug 02, 2019 6:26 pm
by bartbalint
Please let us know how this goes. I certainly would appreciate it!
Cheers!
Posted: Sun Aug 04, 2019 2:55 pm
by torbjrnbergman
bartbalint wrotePlease let us know how this goes. I certainly would appreciate it!
Cheers!
I found out that the learn function in Superior Drummer 3 is all I need !
Just choose the drum I want then click the learn button !
Hit the pad I want !
Repeat for every pad !
Save as a preset in Superior Drummer 3 !
Done !
