SOLVED - Atom stops doing, well, anything after a short time
Posted: Thu Jan 03, 2019 11:55 pm
by landondyer
When I start a new, empty song in Studio One (latest version) I can hit the pads and they make noise for a while . . . then the unit freezes up. Sometimes i can hit notes for 30 seconds or so, sometimes it locks up after just a few. I have to disconnect and reconnect the Atom for *any* button to respond.
Latest firmware on the Atom. I reloaded the firmware just to make sure.
Anyone run into this? This is indistinguishable from broken at the moment. Basically I can't get past the first minute or so of interaction.
Re: Atom stops doing, well, anything after a short time
Posted: Fri Jan 04, 2019 11:32 pm
by landondyer
Solved.
Switching from a USB 3.0 port (on the root hub of my Windows 10 machine) to a powered USB 2.0 hub seemed to do the trick. The Atom was truly unhappy on that old port. After switching, the Atom is stable (half a hour with no issues, versus abjectly freezing in a few seconds).
Now all my problems are creative rather than technical, which is a good place to be.
If any support or engineering staff at Presonus want details, I can provide more info. I have a bunch of experience with the guts of USB and the OS driver stack.
Re: SOLVED - Atom stops doing, well, anything after a short time
Posted: Sat Jan 05, 2019 2:55 am
by Bbd
Thanks for posting your fix!
