Hello all,
I have 2 FS Mobile (1 is a spare) and have no real showstopper issues with them for years. They just chug along. I want to keep then until my next updated PC build, maybe in 3 years. . The FS Mobile is discontinued. UC not updated anymore. I assume i cant install the required UC that the ATOM uses since it will overwrite my current UC and no idea what that will do to FSM.. What will i be missing if I don't install the UC that supports the ATOM? I think it is needed to update FW. I could run it, update ATOM FW, then downgrade? Will I lose what functionality if any not running newest with Atom? Thanks is advance!
Win 10 latest, MSI G41 Z87, I4770K (no OC), 16GB, NVIDIA 710, 2x27" Monitors 1Tb SSD, 500G SSD, 3 platter drives. SYBA Firewire SD-PEX30009, FS Mobile. Monitor2USB, S1 Pro 5 current.
Hobbiest - Mainly Guitars, UVI, Soundtoys, NI, IK, EZ2, SD3, GR5, TH3, Amplitube 4 and 5, Waves GR, Korg 707, NanoPAD2, MicroKey2. Eris 5, B2031A, 2013 R1200GS-LC. |
I'm guessing no, especially with full integration.
Last UC was 1.7.6. https://www.presonus.com/products/ATOM/tech-specs
Skip
There was an earlier issue with having 1.xx and 2.xx versions of UC on the same PC, but I believe that was resolved.
Just in case you still need a workaround, you need to install 2.xx UC first for the Atom, then reinstall 1.7.6 for the FSM, and it should work. |
Thanks, I just saw this reply.
Good to know, lets recover from the holiday $$$ spree and see.
