I think the pads could be brighter. I want it to look like the briefcase in Pulp Fiction.
Still no dark mode.
The new Atom to be released next month - DOES NOT HAVE A POWER BUTTON!! ![]() ![]()
Intel i9 9900K, 32GB RAM, EVGA Geforce 1070 (Nvidia drivers). Dell Inspiron 7591 (2 in 1) 16Gb. |
Here ya go: ANDUL USB Switch Extension Cable, Upgraded USB Extension Cord with On/Off Power Switch Cable for LED Strips, iOS System, etc
https://www.amazon.com/Switch-Extension ... 9800871825 |
jtshupert wroteHere ya go: ANDUL USB Switch Extension Cable, Upgraded USB Extension Cord with On/Off Power Switch Cable for LED Strips, iOS System, etc Well we've had loads of suggestions for these sort of cable switches, and over and over again they don't support data. This one however does! However.. The cable supports 3amp, and the switch only supports 2amps.. so the ATOM must be 2 amps and below. I have just looked at my Atom and googled spec's, I can't find the amps
https://m.aliexpress.com/item/400034399 ... 8292075578
These work. Only issue is that the button ends up near the USB socket it plugs into and not the device, unless you buy a really short USB wire to plug into the device and a USB extension cable.
