47 postsPage 2 of 3
1, 2, 3
Bbd
by Bbd on Mon Nov 11, 2019 5:54 pm
PreAl wrote
Bbd wrotehttps://www.amazon.com/Electop-USB-Switch-Extension-Inline/dp/B07CG2VGWG/ref=sr_1_1?keywords=USB+on%2Foff&qid=1573508144&s=electronics&sr=1-1
"NOTE: This cable is ONLY for power supply(Not support IOS system), NOT for Data transfer."
Thanks PreAI.
Bbd
by leosutherland on Wed Dec 11, 2019 11:36 am
Bbd wrote
rguitar78 wroteI agree, an all LEDs off feature is needed. As for the three brightness options that are currently there, I could also see a 4th level being useful too, but not nearly as important as being able to turn these lights off when not in use.
I have a classic FaderPort and the lights stay off until I boot up Studio One - they also turn back off once I close the DAW. Not sure why they moved away from that mindset.
I just made this a feature request, vote up the post to get Presonus to possibly see it sooner.
https://answers.presonus.com/36425/atom ... re-request
Voted for it. Thanks for the FR.
:thumbup:
Ditto likewise :+1
You can buy short usb male to female cables that have an inline switch - that would work, but it would be better to be 'built-in' to the controller. I defo don't fancy the idea of physically plugging/unplugging the unit all the time! :evil:
On a slightly OT note - here am I mucking about in the Forums, all nicely logged in - when I followed the link to the FR and clicked +1, it said I had to login first :shock:
Didn't ask if I was human though! :D
...said Halo
Studio One Pro v4.6.2
Serum, Diva, Repro, Synthmaster, Massive (+X), Syntronik Bully, MTron Pro, Kontakt/Reaktor, Xpand!2+AIEP3, PPG Wave 3.V, KLC, Generate, Battery 4, CA2600
Reference 4, Reverberate Core
3XS SQ170 Music Studio PC
Windows 10 x64 (1903)
i7 8700 Hexcore 3.2GHz, 16GB DDR4-2666, 1TB 970 EVO M.2 NVMe SSD + 1TB SATA HD
Scarlett 2i4 (G2), Korg Taktile 25, Faderport 2018, ATOM
MSI GE62VR 7RF Apache Pro
Intel Core i7 7700HQ 2.8GHz, 16GB, 500GB 970 EVO M.2 NVMe SSD + 1TB 860 SATA III SSD
Beyerdynamic DT990 Pros, JBL 305P II speakers
by garrykiosk on Sat Jan 18, 2020 9:14 pm
I agree with the need for a hibernate capability great though the Atom is. However, I have found this USB hub with individual on / off switches at a very cheap price which could be considered as a practical fix, and a useful workstation top device nevertheless.
https://www.amazon.com/Generic-7-Port-U ... B007S642BW
by TomTama on Tue Jan 28, 2020 2:09 pm
2013 Mac Pro 3 GHz 8-Core Intel Xeon E5, TB2, 64GB RAM, Mojave 10.14.6, Dell 43" 4K Monitor, Luna Display, 2X Apollo x8, Apollo x8p, UAD OCTO TB3 Satellite, UAD QUAD TB3 Satellite, UAD V9.11, UA OX 1.2, Studio One 5.0, Dangerous Dbox+, Dangerous 2-Bus LT, MiniDSP w/Dirac 2.0, Behringer PowerPlay P16-M & P16-I, Faderport 16, ATOM, Akai Advance 49, Focal Twin 6be, Focal Sub6
by PreAl on Tue Jan 28, 2020 3:05 pm
TomTama wroteThis is what I use https://www.adafruit.com/product/1620
Data goes through it? Can you confirm this works with Atom? I find it hard to believe.
Quote from your link.
"The data lines are not connected through - this is a ground/5V power switch only"
If people make recommendations can they please test first and confirm it works
Intel i9 9900K, 32GB RAM,
by garrykiosk on Fri Jan 31, 2020 1:46 pm
patrickhoonhout wroteAnd how long will the connectors in my Atom USB port last or start to fatigue and result in failure? The square USB ports are not designed to be pulled out daily.
Every other MIDI device, audio device I have has an On/Off switch why should the Atom be any different? I don't understand how a product such as the Atom could be designed without an on/off mode?
Totally concur, but I have come up with a rather satisfying workaround that doesn't involve connecting and disconnecting any cords or cables. . In my studio, I backlight my main console with three different coloured LED up-lighters (rapidly becoming as essential as the Lava Lamp for that 'studio vibe' lol ) Having thought about the Atom 'lights off' scenario, I then reconfigured my anti surge power strips and used a separate 4-way power strip to the three lights, and also a powered USB hub and connected it directly to my DAW. I then moved an Amazon Alexa Dot from a spare room, along with an Amazon Alexa plug from my wifes side of the bed which she doesn't use, With this configuration, I can turn the Atom on and off at will with a single voice command along with my back-lit LED mouse and keyboard and also the studio lights, preventing me having to crawl under the console every time I want to put the LED uplights on.
OK its a workaround, but a satisfying one nonetheless, and I offer it to the group here until the good folk at Presonus offer us a possible firmware update for turning the Atom lights off...
by TomTama on Sun Feb 02, 2020 12:45 pm
I didn't see that caveat before buying and testing. No, it does not work. :cry:
by bartbalint on Sun Feb 02, 2020 4:09 pm
The simple usb switch I use is:
wishacc Male to Female USB Cable Adapter with On/Off Switch-Upgraded Support Power and Data
It does power and data. And so far I am pleased that I can now turn off Atom at night instead of lighting up the whole night sky. 👍
I got it off Amazon for $6.99
Studio One v5.0, Win10 1903, Quantum2, Focusrite Scarlett 18i20, Focusrite Scarlett OctoPre, Yamaha Motif6, MCU-Pro, Wacom pen tablet, ATOM, GR55, Focusrite ASA one, HPD-20, Mackie Big Knob, 8-)
by PreAl on Sun Feb 02, 2020 5:08 pm
Dear Presonus if you listening...
1) Please do not ship gear without power switches in future. Bad bad Presonus. Slap wrist.
2) You could make some money selling us a cable here couldn't you?
by robertgray3 on Fri Feb 07, 2020 1:55 am
Solution:
1. Turn on Mardi Gras Mode
2. Rejoice
Mac OS X Mojave 10.14.6
Mac Pro (Late 2013)
32 GB 1066 MHz DDR3
Dual AMD FirePro D500 3072 MB
Quantum 2
by Bbd on Fri Feb 07, 2020 7:45 am
I use a USB hub to control my keyboard and ATOM.
https://www.amazon.com/Sabrent-4-Port-I ... 8690807089
Bbd
by liamomahony on Wed Feb 26, 2020 9:41 am
I have a USB powered hub which allows me to turn it off so yes that is a solution.
However who on earth would want the whole thing lit up all the time? It makes no sense at all and there should be an option to turn the lights off or set that they only come on when you connect to a DAW. Clearly it recognises a connect because it changes now.
It must be a very simple firmware job to combine a couple of buttons to do it. Come on Pre-sonus it's been far to long like this just sort it out please.
by michaelkrueger2 on Wed Mar 04, 2020 11:22 pm
Yeah, also have my Atom now connected to a switchable, bus-powered hub going into my larger table hub. It´s a workable solution but downright stupid if you think about how much easier and more convenient a firmware fix would be.
Hard to believe this isn't already implemented but here we are.
by robertgray3 on Sun Mar 08, 2020 11:16 am
liamomahony wroteHowever who on earth would want the whole thing lit up all the time?
Mine stays on as a subtle reminder to KEEP IT LIT 24/7
Mac Pro (Late 2013)
32 GB 1066 MHz DDR3
Quantum 2
by lfo2k on Sat May 09, 2020 3:12 pm
Did receive mine today and i am absolutly not pleased by this always on. Makes absolutly no sense. This has to be turned off if not used.
Do it Presonus! Dont waste our time. How would someone even come on the idea that this has to shine in your face 24/7?
It annoys the xxxxx out of me.
by Jemusic on Sat May 09, 2020 3:29 pm
It does depend on what USB port you may be on too. I have got mine in a USB port that is in a separate PCI card and for some reason this powers down when the computer is off so mine goes out. But I realise this is not a workable solution for everyone. It does light up the whole studio! Are there any settings for what your USB port does when the computer is off? I will check in with the developers and see if this can be changed with firmware.
by lfo2k on Sat May 09, 2020 3:49 pm
"when the computer is off" <- Dude it has to be off when not working wihin Studio One. Not first at the point where you shut down your PC.
Why was this even released without power-button.
by paullindqvist1 on Sun May 24, 2020 8:36 am
I recently got a Novation Launchpad X. You can turn off the lights by pressing two buttons, takes a 1 second and it turns back on by pressing any button.
Presonus could of course do something similar with their software if they wanted to...
by michaellauer on Fri Jun 19, 2020 9:41 am
Let me toss in another vote for a proper USB shutdown mode.
That said, even in standard operation mode, I find the LEDs too bright. How about a LED mode where the main pads are off unless they sense a pressure?
47 postsPage 2 of 3
1, 2, 3
