Page 1 of 2
Edit pad note/pad banks
Posted: Wed Nov 14, 2018 7:22 pm
by staffordwilson
Have scoured the downloadable manual for the ATOM and worryingly can't find any reference to being able to edit the note that pads trigger. Or to be able to edit any of the pad banks and save custom banks. As I use a specific pad bank setup (Xpress Pads technique), if I can't create custom pad banks, the ATOM's not going to be for me.
I imagine this will also impact those people who want to setup pad banks for specific scales etc...
Would love to find out I'm wrong about this - perhaps Presonus are working on a pad bank editor software?
Re: Edit pad note/pad banks
Posted: Thu Nov 15, 2018 6:56 pm
by andreasrethwisch
This also concerns me. Without this feature, my interest drops to zero as some of my software pretty much needs me to be able to do this.
Posted: Fri Nov 16, 2018 2:51 am
by themuzic
Excuse me for not understanding completely. But are you talking about the touch of the pads themselves or the pads and the sounds they trigger in Impact?
I am going to be doing a video series on the Atom so I want to make sure I understand.
Thanx in advance.
Posted: Fri Nov 16, 2018 12:28 pm
by andreasrethwisch
Personally I want to know about using the pads outside of impact.
Posted: Tue Dec 04, 2018 12:43 pm
by neilzaza
I need to know this exact same thing! I am using Superior Drummer 3 and would like to construct my kits/placement on my Atom. Yes, I can change the MIDI note number in SD, but then if I change a kit it won't play back correctly with the MIDI information recorded. I know there is no editor for Atom, so I wonder how to change the MIDI note that a pad is sending. Is this even possible?
Thanks!
Posted: Tue Dec 25, 2018 7:18 pm
by ratsgym
neilzaza wroteI need to know this exact same thing! I am using Superior Drummer 3 and would like to construct my kits/placement on my Atom. Yes, I can change the MIDI note number in SD, but then if I change a kit it won't play back correctly with the MIDI information recorded. I know there is no editor for Atom, so I wonder how to change the MIDI note that a pad is sending. Is this even possible?
Thanks!
Have you found out how to use the atom on superior drummer
Posted: Sat Dec 29, 2018 7:53 pm
by Munarheim
" being able to edit the note that pads Trigger"
I have the same question. I have read the manual but can't find any Information about how to Change the note the pad will Trigger. Or did I miss something?
For example I want to use the pad outside of Impact and use it with East West Stormdrum. Would be nice to be able to make some own Presets for Atom. Anybody has a solution for that?
Posted: Sun Dec 30, 2018 1:32 pm
by neilzaza
You can easily use Atom with Superior Drummer (or any other program for that matter), but as I see it now, there is no way to edit the MIDI Notes that come out of the Atom. Bummer...
Posted: Mon Jan 07, 2019 6:10 pm
by dereksucharda
I see where this thread has kind of died with no real answers. "The Muzic" has made several good videos and I see where he has expressed interest in this thread, I hope he responds with a link to a video that answers these questions as he has done in the past.
My question is "is it possible to assign certain sounds in a kit to a different pad from that which the default. For example if in one kit the kick is on pad 7 and on another kit the kick is on pad 5 can I set it up where anytime in the future, if I open that kit the kick will always be on pad 1. i want my fingers to have a predictable place to go for the kick, snare, open high hat, closed high hat, etc....
Not sure if this is the same question others are asking or not. Thanks.
Posted: Tue Jan 08, 2019 6:53 pm
by Jemusic
Create the pad setups you want and save them as user presets. When you load your user presets everything will come back the way you saved them.
Posted: Wed Jan 09, 2019 10:49 am
by dirkschroeter
I also miss the function to change the mide note value for the 16 pads in atom. When in "Keyboard Mode" it should be possible to change each pad to a note value that fits to an instrument other than impact XT.
Posted: Thu Jan 10, 2019 7:04 am
by heinzhupfer
HI:)
In Cakewalk there are Drum Maps where you can assign incomin notes to other notes on different VSTs1
For Studio One the only way to do this is:
The Chorder Note FX plugin can be a drum re-mapper. There's no presets for that use case but it can change the pitch of notes to any other note, if you set it up that way.
Greetz:)
Bassman.
Posted: Wed Feb 13, 2019 1:31 am
by ionian
This is what I'm trying to figure out and I can't seem to get a straight answer.
I want to change the specific notes the ATOM plays on each pad. According to the manual it says Pad 1 = C, Pad 2 = C#, Pad 3 = D, Pad 4 = D#, etc.
I'm using BFD3. I want to change the notes the ATOM plays, I DON'T want to use a different keymap because it's no good since the midi notes will be different and will slow me down while editing since they're not the standard drum notes (C is Kick, D is snare, F# is closed hat, etc.)
So I want to change pad 1 = C (Kick), Pad 2 = D (Snare), Pad 3 = E (Rimshot), Pad 4 = F (Drag) etc. Is this possible? If not, then I'll pass on the ATOM. I've been using the Maudio trigger finger for this for ages (which does allow you to program what pad plays what note). I was hoping to move to the ATOM just because it's tightly integrated with Studio One, which I use, but if the ATOM is incapable of doing this very basic feature, there's no reason to move on from the trigger finger.
Posted: Mon Feb 18, 2019 11:48 am
by ionian
Lol guess that's my answer
Posted: Mon Feb 18, 2019 12:57 pm
by reggie1979beatz
It's frustrating for sure. I don't know how to do it. It does many things well but this seems to not be one them.
Posted: Mon Apr 22, 2019 2:09 pm
by bluesdelux
If I understand correctly, you can change the midi note assigned to a pad in Impact at least. Select your pad, then go to the upper right hand corner and type in the midi note you want to assign to it.
The Studio One manual has more details beginning on page 288. Page 290 covers the menu in the upper right hand corner.
Outside of Impact using a third party instrument I'm not sure.
A possible work around would be to sample drums sounds from your drum apps and bring them into Impact. I've seen some videos where a drum loop was sampled from within a S1 track, and broken down into individual samples and assigned to the Impact pads.
Hope this helps!
Posted: Tue Apr 23, 2019 8:35 pm
by Mr. Pilo
Unless they make an editor for it, it's not possible.. AAAHHHHHH THIS IS TERRIBLE!!!!! Some vst's don't have a midi learn function so the only way to get the certain hits lined up with the pads is by changing the notes on the pads but if that can't be done then it's basically useless.... I hope someone can crack the code soon... I just got the atom today ESPECIALLY to be able to use it in this way... Very disappointing :( :cry:
Posted: Wed Apr 24, 2019 11:14 am
by andreasvenzke
Hello!
I made myself a chorder preset to use my atom with XLN addictive drums. So I have the sounds on the pads I like best for finger drumming. It‘s really easy to do. Now everytime I use addictive drums I load my preset in chorder and that‘s it.
Andreas
Posted: Wed Jun 12, 2019 12:29 am
by Guido Negraszus
Just bought an Nektar Impact LX25+. I was surprised how easy it is to edit the drum pads.I have a lot of Kontakt percussion libraries. Usually they spread a ton of percussion sounds across the keyboard. Over the years I have my favourites, usually just a few out of the whole library.
So, in Impact LX25 I just press "pad learn", press the drum pad I want and then press the key on the keyboard which holds my favourite percussion sound. Done. Took me just 10 minutes or so to do all my favourite percussion sounds on 16 pads.
Is this the issue discussed in this topic? I would love to this with ATOM but can't figure it out.
Posted: Thu Jul 04, 2019 12:12 pm
by chrissederqvist1
Is this still an issue?
No editor for changing the notes that gets triggered by Atom?
Wow.
I was two seconds from clicking "confirm order" on the Atom controller, but now I'm letting it wait.
Also, I purchased the "MVP Loops - Core Drum Kits Vol. 1", boasting about being made specifically for Impact XT (And Atom I thought), but inside I find Impact kits mapped all over the place...
So without a way to either:
1. Create a macro or something that goes through all pads and maps them automatically inside S1 (but this limits applications outside the S1 realm)
2. Change the notes being triggered using presets on the Atom controller for different applications
I'm not buying...
