I just got mine, and I have to say I was surpsised. Yes, I knew you can't change the mapping. There are ways around that. However, when you use a 3rd party drum plugin in Studio One, the Atom goes into keyboard mode, and only allows you to use 13 out of the 16 pads. With the huge amount of soft buttons around the pads, why would you use the pads as octave transpose buttons? Thats is outrageous. It's practiacally impossible to use this device as serious drum pads, and as long as this is not fixed, I will not recommend anyone buys the Atom.
Its curious alright - no straight midi mode - mind you Maschine mikro mk3 (which I replaced with the Atom took a while to implement that.
So Maschine/Battery software when run has that awful keyboard mode - but when I'm running Addictive Drums 2 the pad is spread straight across 3 banks - which I'm happy enough with as the articulations are what AD2 is about. Have to investigate further - as just noticed this. |
I can't believe this is still not possible!
I have the same problem as the OP- I want to be able to re-assign midi notes (and ideally the LED colours as well) so I can use the Atom with any instrument, not just Impact. Like the OP, I'm trying to set it up with Superior Drummer 3. Even just a NoteFX plugin that remapped midi would be enough (although first-class support would be great)... |
Yes a drum map editor built into Studio One, like Sonar has (although it's UI is poor), is definitely needed.
1st of Feb 2021, and the problem persists...
I have wanted to buy the Atom for some time, but I am about to give up. Against my desire, it will have to be a Maschine Mk3, which costs more(!) This from a long-time S1 devotee! Come on guys; you are either missing sales, or you are making sales only to dissapoint buyers. This is nonsense. Adrian |
