I've already updated to the UniversalControl-v49805 and my mac os version is 10.13.2. i found that my Preset +/- button doesn't latch, i have to hold it down to scroll through presets. In the vids i've seen they hit the preset button then use the up down buttons to load presets and are able to hit the pads with their left hand to test the sounds because the Preset +/- button stays latched. Did something change with the Universal Control Update? also am i the only one experiencing this?
I don't think this is fixed in Windows at least.
According to manual page 19. "When the Instrument plug-in window is open, you can quickly change presets by pressing Preset +/- button. Press and hold for momentary. Press and release to latch. While holding the Preset +/- button, use the Up and Down buttons to audition presets. To select the current preset, simply disengage the Preset +/- button." Well I cannot get it to latch. Not only that, hold preset +/- sometimes changes the sound (first few goes maybe), and sometimes it does not. Often Studio One loses Focus elsewhere. Very frustrating! This is key functionality I expect from a controller. |
Enter the latch mode:
First press and hold "Preset+/-" button, than press Shift for about > 1secs |
gottfriedbergmair wroteEnter the latch mode: Agreed. The Preset button will then light up. Then use the Up/Down buttons.
Bbd
Please add your specs to your SIGNATURE. Search the STUDIO ONE 4 ONLINE MANUAL. Access your MY.PRESONUS account. OVERVIEW of how to get your issue fixed or the steps to create a SUPPORT TICKET. Needs to include: 1) One Sentence Description 2) Expected Results 3) Actual Results 4) Steps to Reproduce. OS: Win 10 x64 Home, Studio One Pro 4.1, Notion 6, Series III 24, Steinberg UR44, Haswell CPU: i7 4790k @ 4.4GHz, RAM: 16GB, Faderport 8/16, Cental Station Plus, PreSonus Sceptre S6, Eris 3.5, ELAC Sub, Akai MPK261, Roland T6, ATOM |
Okay the trick is: HOLD AND Press the "Preset+/-" button,
than press Shift while holding "Preset+/-" AND than RELEASE the "Preset+/-" button FIRST! Gottfried |
How to use the "Preset+/-" button on ATOM:
Gottfried |
gottfriedbergmair wroteOkay the trick is: HOLD AND Press the "Preset+/-" button, Thanks. I knew I had to be doing something wrong ![]() |
Thanks very much for this.
I have to say I really don't like this as a combination. I shall just have to print out the diagram (thanks for this) until it sticks. And what a pity the dial does not work as well as the up and down buttons for this! |
