So I installed everything including the Universal Controller and StudioOne 4.0 on my Mac. I plugged it in and everything seemed to work fine. I also played around with it using GarageBand a bit and it was fine. I didn't use it for a few weeks because I got frustrated with it.
I then installed Logic Pro to see if I liked using it with that and now it's all wonky. When it's plugged into my Mac all of the lights flash and cycle through different colors like it's at a rave. It didn't do that before. When I open up StudioOne the flashing stops and it works as it did before when using StudioOne. If StudioOne is not open it keeps flashing and does not work at all in any other DAWS. As soon as I open StudioOne and go to Logic Pro the lights turn off but i'm able to play instruments with it as if it works, but the pads are not lit up, even when I hit them. Only the buttons along the left and right are lit. It worked fine in GarageBand 2 weeks ago and the lights never flashed like this incessantly. I don't know if this is an app issue, a driver issue, a Universal Controller issue or maybe a hardware issue. I installed the latest firmware through UC. Is there a way to reset the unit to factory settings. Is anyone using a Mac that is having an issue with it like this? I'm new to these units so I'm NOT saying this couldn't be a user issue. I just wanted something to make programming midi drum tracks easier. |
