Anyone care to convince me a Faderport is worthwhile?
Posted: Mon Mar 15, 2021 4:47 am
by GMHague
I've got a Novation controller, bought it cheap at a school auction where no one knew what it was. Transport, eight faders, rotary controls everywhere ... But by the time I've confirmed that I'm actually adjusting the parameter I want, I could have tweaked a half-dozen using the mouse. Aside from the Transport I see little improved workflow or better mixes. However, I can see how the single Faderport might be an advantage ... might.
Can anyone convince me the money spent is worthwhile?
Re: Anyone care to convince me a Faderport is worthwhile?
Posted: Mon Mar 15, 2021 8:08 am
by Tacman7
Remember the BCR2000 I think it was...
I wanted one of those to mix with. I got it but never used it.
Turns out I don't mix, I just put compressors everywhere and ship it out.
Not knowing my workflow or thinking I would like a new workflow is the problem there. Hard to know what you're in the process of developing.
If you're like me you don't know until you try it. Like a mic preamp, I can't try it out, I have to own it and then I can tell if I want to keep it.
I did get an original faderport long time ago, still there, works fine I use it off and on. I use the contour shuttle, that can really change the way you work.
There's a lot of features on the new faderports, read up on those and see if it would fit into your workflow.
Long as you're here...
Posted: Mon Mar 15, 2021 10:11 am
by garyshepherd
I have a FaderPort 2018 and I think it is really good - couldn't do without it now. But it depends what you think you want.
Posted: Mon Mar 15, 2021 6:28 pm
by peterbirch
From what you said my short answer is NO.
If you have used a mouse for many years, like me, then it is almost like it is hard wired into muscle memory. That is, if you see a fader you move it without thinking whereas with a physical one fader you will have to mentally take steps to move it etc.
What
is worth the money is the FP8/16.
It is funny but using the FP8, I still move the volume faders by mouse (muscle memory) but 90% of the time use the faders on editing plugins. The Fp8/16 also has a lot of useful buttons/shifted buttons that really speeds up the workflow. I think this is one of the best pieces of equipment that Presonus has released.
I see Presonus has now released "grouping" so that multiple FP's can be grouped together.
I have this vision of me getting another FP8 and high platform shoes and with a FP8 under each hand I could become the FP Wizard ..."sure plays a mean FP"...
Posted: Tue Mar 16, 2021 10:29 am
by garyshepherd
One fader is perfect - faderport on the left, mouse on the right. When you click a channel or track , you then know the fader relates to that track. Ability to pan with the faderport also great. With more faders you will have to know which fader is for which track - with one it is so easy and the workflow so comfortable. So the cost of the Faderport 8 is not worth it for me - but it's up to you - just don't think more faders means better. It depends on how you work - and one fader is plenty for me and simple to work.
