I love using the faderport transport controls while editing/recording, and while I know the loop button turns it on and off, is there a way to set in and out points using the Faderport buttons?
In Logic, you simply hold the loop button and press the reverse or forward buttons. Is there a way in studio one?
-John
by garyshepherd on Tue Aug 18, 2020 11:34 am
You may need to create a macro and then assign it (or them) to the F function buttons.
____________
iMac 27" 3.3 GHz Intel Core i5, 32 GB Ram, Catalina OS 10.15.7, 64 bit, Studio One 5.3 Professional (always the latest) , Reason 11, Melodyne 5 Editor, Digital Performer 10, Korg Legacy Wavestation and M1, Arturia minimoog V, Helix Native 1.93, Bias FX 2 Elite, Superior Drummer 3, EZkeys, EZbass, Alesis Q49, Audient iD14, Faderport 2018, Gibson Les Paul Standard, James Tyler Variax JTV-59 and other gear.
by Jemusic on Tue Aug 18, 2020 10:33 pm
Not directly I don't think but there may be a way. Which Faderport are you talking about as well?
Do you know that if you place the cursor at one position and hold Alt and Press Num Pad1, the Left side of the loop will assume that setting and if you move the cursor to a later position and hold Alt and Press NumPad 2 the Right side of the Loop will assume that setting.
So you could program two of the user buttons for those two functions. You could scroll using the large encoder to the desired loop start position and set the left side of the loop. Scroll again to the desired right loop setting and set the right side of the loop using the second user button.
Specs i5-2500K 3.5 Ghz-8 Gb RAM-Win 7 64 bit - ATI Radeon HD6900 Series - RME HDSP9632 - Midex 8 Midi interface - Faderport 2/8 - Atom Pad- iMac 2.5Ghz Core i5 - High Sierra 10.13.6 - Focusrite Clarett 2 Pre & Scarlett 18i20. Studio One V5.3 (Mac), Notion 6.8, Ableton Live 11 Suite, LaunchPad Pro
by darrenporter1 on Wed Aug 19, 2020 8:01 am
you can also set up a macro in S1 to "set loop to selection" and assign that macro to a function key on the FP.
I agree that it would be a nice feature to somehow do it directly from the FP1/8/16.
Studio One Professional 5.whatever, Harrison MixBus 32c v.6
UA Apollo QUAD, QUAD Satellite, PCIe DUO
FaderPort 8, Softube Console 1, JBL 306P Mk.II Monitors
by johnboulware1 on Tue Sep 08, 2020 10:38 am
Thanks guys, these are helpful! I ended up setting F3 to Set Loop Start and F4 to Set Loop End. Works easily enough to get the job done.
