Can someone please help me, ive been talking to support for a week but no help..
ive tried everything, disabling crsutil, disabling sip, reinstalling, fresh OS nothing seems to work. But sometimes the interface just decides its going to work?? out of the blue.. This is a new unit too. I can see sound coming into and out the main outs 1 and 2 in UC but no sound from my monitros. I can confirm this is some weird bug because with the exact same setup it sometimes just works.. here's a quick video of the issue at work https://www.swisstransfer.com/d/dda319c ... 94dac29803 Also this static noise only happens when the issue happens, so when the interface works.. the static noise is gone too.. im lost |
What OS are you on? What Quantum interface do you have?
Could you link it on YouTube? I keep getting a non private connection warning.
Same issue with my quantum 4848..
Tried everything softwarewise, same results. Main issue noticed: hardware seem initialisation abnormal with panel lights lights sequentially then stop, power led dimly lighted, tb led dark -not lighted blue -, unit recognized in windows app and uc, will show activity in uc output screen. But no actual hardware sound. Raised a ticket, done all suggestions, same issue. Finally open the unit, measured the test points. 3.3V is ok, +VA is 13V, -VA is -13V. But +5VD is 1.9V and +5VA is 0V, and the 5v regulator ic is ST N29150, 4 pin with inhibit. I would appreciate if anyone could provide me with q4848 schem atic diagram so i could check if the regulator is ok or probably inhibited by any other shorts in the circuits.. Thanks in advance.. |
