When setting the Pre Level for Snare hits should the green Input lights show more at the top of the scale in order for the much softer Ghost Notes to be picked up sufficiently?
Also, is this level done regardless of what is showing on the DAW meter (set at Unity) assuming if clipping there it can be turned down within the DAW? Or, are you setting the Pre Level while watching the DAW meters for clipping? Thanks |
