Hi all,
I used to have 2 stabeboxes connected in series to a StudioLive 32sc, and used that as my main interface. AVB was a lifesaver to keep the installation simple and clean. For various reasons I need to replace the mixer with a regular interface, and was hoping to stay in the Presonus world. However, none of the interfaces support AVB, so I have no way of connecting the stageboxes. I could get s Motu 828es interface, or use s 16r, but I’m not a fan of Motu, and the 16r is not really a good replacement for a full interface given its limited from panel controls etc. For the moment I’m learning towards getting a motu lp32 to convert the AVB streams to adat, and then connect those to the adat inputs of an interface, but I would have loved to be able to skip that step. If only the Quantum interface had an AVB port… Any other suggestions or ideas would be much appreciated. Thank you |
My question is why do you need to change from the mixer to an interface? Are you aware that there is now an "interface mode" for the series 3 mixers that gives direct output routing from the daw?
Only a Series 3 mixer can control the Preamps on an NSB. You either commit to that or change it out.
