Hi there everyone. I am planning to buy a Quantum interface and am trying to decide between the original Quantum (26x32) and the recently released Quantum 2626.
The original Quantum is at higher price point, but my budget is flexible and there are some open box Quantum units for just a couple hundred bucks more than the Quantum 2626 (which is newer so not a lot of used units out there, that I have seen anyway). I have some questions about specific differences between the units, that go beyond the obvious feature differences. In terms of features, both models have the things I actually need, thus making it a tougher decision. My specific questions: 1-Is the Quantum 2626 the exact same audio quality and specs in terms of mic pres, A/D conversion, D/A conversion, S/N ratio dynamic range, etc. Is there any additional sound quality benefit of getting the original Quantum, in any way? 2-My computer is a 2018 Mac Mini that uses Thunderbolt 3, with a USB-C form factor connector. That means that with the newer Quantum 2626 I could just plug in a normal thunderbolt 3 "C to C" cable, but with the original Quantum, I would need to use a Thunderbolt 3 to Thunderbolt 2 adapter. My question is, is there ANY penalty/consequence in terms of latency, stability, by using an adapter and running the older thunderbolt 2 Quantum unit, on my newer Thunderbolt 3 computer? The whole point of getting a newer Thunderbolt interface, is for super low latency, stable, rock solid operation. If needing to use the adapter creates any drama or complications, that would sway me towards getting the Quantum 2626. 3-In addition to using the interface to record and mix, I will also be using the interface to listen to music, while working and typing at the same desk for long stretches of time. This means I adjust the volume knob, for adjusting the listening level of iTunes, very often, and want it to be a comfortable experience. I see that the Quantum 2626 has a mid-sized control knob that looks kind of crowded in with some other knobs, whereas the original Quantum has a huge control room knob that’s not crowded in with other stuff. Has anyone used the monitor controls on both and found one of them more comfortable or better feeling than the other. I know this is getting more than a little anal retentive, but this is the control I will use the most and want it to feel nice when adjusting, not loose or wobbly, fiddly to reach for and adjust, etc. I think that’s everything for now. In general I am leaning towards the original Quantum since some of the extra features, while not necessary, could be useful. Also, having most of the mic pre inputs on the rear would make for a neater setup in my particular studio. However, I am open to everyone’s opinions. Thanks! __________________ Dan Steinberg Pro Audio Product Manager http://www.linkedin.com/in/danielmsteinberg |
steinber wrote1-Is the Quantum 2626 the exact same audio quality and specs in terms of mic pres, A/D conversion, D/A conversion, S/N ratio dynamic range, etc. Is there any additional sound quality benefit of getting the original Quantum, in any way? - Hey Dan...I believe there is a comparison chart on the main Presonus website in the "downloads" section that breaks down the specs of both of these units. steinber wrote2-My computer is a 2018 Mac Mini that uses Thunderbolt 3, with a USB-C form factor connector. That means that with the newer Quantum 2626 I could just plug in a normal thunderbolt 3 "C to C" cable, but with the original Quantum, I would need to use a Thunderbolt 3 to Thunderbolt 2 adapter. - I own the Quantum 2626 running a Late 2012 Mac Mini using the TB adapter and I must say it is solid as a ROCK! (see my earlier post about issues i had = (make sure to use an Apple TB cable) With using the Apple TB cable 3 to 3, your machine should be rawkin and super speedy! steinber wrote3-In addition to using the interface to record and mix, I will also be using the interface to listen to music, while working and typing at the same desk for long stretches of time. - I'm using the (passive) Mackie Big Knob to control output of my 2626 and I love it! It's built like a tank. Another passive monitor controller I recommend is the A Design Audio "ATTY" super small foot print and sturdy. I Love my Quantum 2626...all those inputs and outputs and the mic pres sound punchy and clear. I say go for the 2626!! Good Luck!
"What Time Is It?" - Morris E. Day
http://www.curtbisquera.com Quantum 2626 Interface Apple (Late 2012) Mac Mini Mac OS Catalina / 10.15.7 2.3 GHz Intel Core i7 16 GB 1600MHz DDR3 Intel HD Graphics 4000 1536 MB |
I have a purchased a Quantum 2626, and although I like the audio premamps etc, my midi does not work correctly. Notes hang about 2 minutes into playing weather I am using Logic X, Hauptwerk (Virtual Pipe Organ Software), Studio 1 or Cubase on the Windows side of my Mac.
One thing you might want to consider is if you are going to put the Quantum in a rack. If you are, 8 inputs on the front of the unit is a good thing. I can't remember if the original Quantum is set up this way. I miss my Fire Studio Project. It worked properly for years and also had an on/off switch the front too. |
I have the original and I love it. Preamps are so clean and the latency is nearly nonexistent which is what I needed being that I use a hybrid workflow including pipeline XT.
Mac Mini (Late 2014)
Might as well add the Quantum 2 to the discussion.
I can certainly make use of the inputs in the 2632 or 2626, but most of the time, the I/O available on the Q2 would cover my needs. The low latency performance for virtual instruments, good/excellent-sounding preamps, and the MIDI I/O for either connecting a MIDI guitar controller or my Roland sound module is the main attraction. In my case having two inputs on the front and everthing else in the rear would work best, but I won't rule out the 2626. Controlling the preamps from Studio One (and FP8?) is another draw to the original Q or Q2. |
robertgray3 wroteQuantum 2 has been discontinued. I love mine but I would not recommend it due to that fact. Thank you for weighing in. As a reader more than a contributor here, I alway appreciate your straight responses. |
I like my 2626 as it is very clean on pre’s and simple in the UC and no way to twiddle other than RTA (button on/off) so not much to go wrong there, I really like the RTA to have a little forewarning of the EQ, have had no problems with MIDI so can not help there.
The Magazine Sound on Sound declared that it was the TB3 audio device with lowest latency when it came out if I recall right.
Setup of the 2626 was easy.
Connection via TB2 cable to apple TB2/TB3 adapter to a 2012 Mini yielded a steady blue light. UC indicated a need for a firmware uprade. No issue. MIDI was enabled in UC but a restart was required for it to appear in the macOS AudioMIDI setup utility. A Roland GI-20 MIDI guitar converter is hooked up to the MIDI ports and works great. That means one less USB cable as I don't to use a separate MIDI interface. When looking into the options, I wasn't sure I'd like the jacks in the front. My general setup is not set-and-forget, but neat cable management was a priority. My desk does have a cable hole to route cables underneath and they surface right near the front jacks of the 2626. Perfect! Front jacks: An electric guitar is always in the first instrument jack with either a bass or an acoustic guitar with a magnetic pickup in the second. My Boss GP-10 can now remain connected to line inputs 3 and 4. The front jacks offer flexibility in swopping out sound module multi-output cables with two condenser mics that I haven't used in a while. Way to go Presonus! |
