Noise
Posted: Sat Jul 04, 2020 7:35 am
Hello All,
I'm new to the forum and excited about my PreSonus Quantum. I recently upgraded from a Behringer UMC404HD that I was rather happy with but wanted to experiment with a lower latency device as I dive deeper in to the DAW realm of sims, etc.
My first step in trying out the new unit was to just playback some of my existing tracks. Generally, these are 12-16 channels with various delay, reverb and amp sims. A compressor on the master bus. These recordings performed fine on my UMC404HD at 128 or 64 samples. Generally though, when mixing I increase the buffer to 4096.
When I plugged up the Quantum, I started experiencing "static" for lack of a better term. I wouldn't normally associate this sound with "dropouts" and my CPU usage is minimal at this point. Anyway, I opened a ticket but still waiting on a response. I thought I'd post to this forum to see if anyone has had a similar issue and circumvent the ticket process.
Here are a couple of sound files:
https://drive.google.com/file/d/10Ej5mu ... sp=sharing
https://drive.google.com/file/d/108rmls ... sp=sharing
I'm running a fairly capable mobile setup. 10750H processor with GPU, 16MB of memory. I have been running tests with the hardware monitors open and have rarely maxed beyond 35-40% CPU and less for memory.
I was thinking computer cables or the Tbolt adapter. My analog signal path is fine...as I said earlier, I get a steller output from my Behringer unit.
