Hello All,
I'm new to the forum and excited about my PreSonus Quantum. I recently upgraded from a Behringer UMC404HD that I was rather happy with but wanted to experiment with a lower latency device as I dive deeper in to the DAW realm of sims, etc. My first step in trying out the new unit was to just playback some of my existing tracks. Generally, these are 12-16 channels with various delay, reverb and amp sims. A compressor on the master bus. These recordings performed fine on my UMC404HD at 128 or 64 samples. Generally though, when mixing I increase the buffer to 4096. When I plugged up the Quantum, I started experiencing "static" for lack of a better term. I wouldn't normally associate this sound with "dropouts" and my CPU usage is minimal at this point. Anyway, I opened a ticket but still waiting on a response. I thought I'd post to this forum to see if anyone has had a similar issue and circumvent the ticket process. Here are a couple of sound files: https://drive.google.com/file/d/10Ej5mu ... sp=sharing https://drive.google.com/file/d/108rmls ... sp=sharing I'm running a fairly capable mobile setup. 10750H processor with GPU, 16MB of memory. I have been running tests with the hardware monitors open and have rarely maxed beyond 35-40% CPU and less for memory. I was thinking computer cables or the Tbolt adapter. My analog signal path is fine...as I said earlier, I get a steller output from my Behringer unit. |
the links don't word. thx
_.~"~._.~"~._.~"~._.~"~._
Studio One 5 Pro Quantum, Quantum 2, Didimax FS, FirePro, Firestudio Project, Firestudio Mobile, Art Tubeopto, DBX 386, Maschine 3, Hydrasynth, Analog Heat, Zed 14, Motu MTP AV, Keystep, Beatstep Pro, RD-8, Monomachine, machinedrum, Octatrack, Analog Four, Minilogue XD, Korg Arp, uWave XT, Virus C, Poly Evolver, Mono Poly, MKS-70, Mks-80, Pulse Plus, Blofeld, BassStation 2, ESQ-1. Korg Legacy, Arturia V, NI Ultimate 10, ImpOSCar2, BFD3, DCAM, Largo, Waves Gold. Acer 7VN-593G, Win10 Pro |
Hi Todd,
Did you end up getting it to work fine ? Could you solve the problem? My Quantum is making that kind of constant "static" noise and it only does it at 44.1 and 48 kHz. I changed the Thunderbolt 3 cable and tried other things bus still keeps making this unbearable noise. Any suggestions anyone???? |
This is probably related to C-States and CPU power saving features.
Which Version of Windows are you running?
Could it be that you have your pc, monitor speaker and audio interface in the same power outlet or power socket. Try to have all three in different power outlets.
My system
Intel Core i9-10900K Processor Noctua NH-U12A CPU cooler Gigabyte Z490 VISION D Samsung 970 EVO Plus 1TB SSD Corsair Vengeance LPX DDR4 3200MHz 64GB MSI GeForce RTX 3080 Ti Gaming X Trio 12G StarTech Thunderbolt Cable 2M (TBOLTMM2MW) StarTech Thunderbolt 3 to Thunderbolt 2 adapter (TBT3TBTADAP) Neumann TLM 102 microphone Presonus Quantum Windows 10, Ableton 11, Cubase 10 |
