Hello I’m new user of presonus quantum audio interface.
My setup:
Windows 10 x64.
Cubase 10.
i7-8770k. 32GB ram.
Presonus quantum.
I’m trying to figure out how to monitor audio inputs with insert and send effects on heavier projects (some heavy cpu plugins and buffer is 1024 or 2048) without latency.
Since quantum doesn’t have hardware monitoring I’m forced to monitor thru daw and on bigger projects there’s so much latency that it’s impossible for singers to get a good performance due to high latency.
Please help
by ts-12 on Sat Aug 31, 2019 8:06 pm
Any help or suggestion appreciated
by PAE Seth on Mon Sep 16, 2019 8:40 am
Not with Cubase you can't. Unless there is a low latency monitoring option that bypasses the plugins.
Studio One has a feature that allows for Low Latency Input monitoring even at high buffer settings. However, it disables any plugin that goes over 3 ms latency, otherwise, the feature wouldn't work. Quantum was designed to utilize this feature, hence why the internal round trip latency of the unit is lower than any TB product in it's class.
Now, personally, I would never have that much processing on while attempting to track audio. I do things in stages.
While tracking, I use low cpu / low latency plugins until I am finished with all recording. Save that session, then open another version of it for mixing. Only then, do I use heavier cpu use plugins.
If something needs to be re-tracked, then you bring it back to the tracking / recording session, do the business, then export the stem.
PC #2: ASUS X299 Prime Deluxe II, i7-7820X 8c/16t, 16GB 2666 MHz DDR4, GTX 1060 3GB, Samsung 970 EVO NVMe M.2 SSD (Win10 Pro), Samsung 860 EVO SATA SSD (Win11 Pro), OWC Aura 512GB NVMe M.2, 2 x 1TB HDD
Mac: 2010 Mac Pro 6 core 3.33 GHz, 32GB 1333 MHz DDR3, AMD RX 5500 XT 8GB, Alpine Ridge Thunderbolt 3 Card, Aquantia 10Gbps AVB card, Dual eSATA PCIe + Stardom 8xHDD Raid Tower
by TerjeNorway on Sun Sep 22, 2019 10:34 am
This is why you freeze tracks. If you wanted direct monitoring you picked the wrong Interface.
My system
Intel Core i9-10900K Processor
Noctua NH-U12A CPU cooler
Gigabyte Z490 VISION D
Samsung 970 EVO Plus 1TB SSD
Corsair Vengeance LPX DDR4 3200MHz 64GB
MSI GeForce RTX 3080 Ti Gaming X Trio 12G
StarTech Thunderbolt Cable 2M (TBOLTMM2MW)
StarTech Thunderbolt 3 to Thunderbolt 2 adapter (TBT3TBTADAP)
Neumann TLM 102 microphone
Presonus Quantum
Windows 10, Ableton 11, Cubase 10
