Discuss Quantum Series Interfaces Here
The Quantum 2 works amazing in Studio One. 16sample buffer! What an amazing way to play VSTi and record acoustic instruments/vocals.
One issue I keep running into is that whenever S1 is open, or has been open, Windows seems to loose the Quantum as an output. I can still see it, but for example Splice or Spotify have no sound. They play and behave as if there is a sound card, but no sound is produced.
Does anyone have this? I never had this with the S192.
S1 5.1 - Windows 10 - i9 7900x 32mb - interface: Quantum 2 - CS18ai
by Trucky on Tue Jun 05, 2018 8:37 pm
webhamster wroteThe Quantum 2 works amazing in Studio One. 16sample buffer! What an amazing way to play VSTi and record acoustic instruments/vocals.
Just make sure that all your audio interfaces in Windows have these options unchecked:
Download the STUDIO ONE 5 PDF MANUAL. Access your MY.PRESONUS account.
Windows 10 Pro 64-bit (20H2), Studio One 5.1.1 Pro | Notion 6.8 | Universal Control v3.4.0.61835
StudioLive Series III 32 v2.4.17466
by webhamster on Wed Jun 06, 2018 7:56 am
Great, thank you!
That solved it indeed :)
by Trucky on Wed Jun 06, 2018 8:00 am
Glad to help!
by andysmith18 on Mon Aug 27, 2018 7:25 pm
I have the exact same symtpoms: Quantum 2 outputs show normally on the Windows playback device window, and the meter works as if its working fine, but there's no output to the Quantum. Works beautifully in Cubase using ASIO driver.
Trucky's suggestion didn't work for me, unchecking (or checking) the Exclusive Mode makes no difference.
Anyone have any other suggestions?
Thanks,
Buzz
by Jim Roseberry on Tue Aug 28, 2018 8:23 am
Try switching the Default playback device to a different port... then back to the desired (I assume Main Output 1/2?) port.
Close your web-browser and reopen it.
Do you now have Windows audio from the Web?
With some audio interfaces, they won't play Web audio unless the sample-rate for the audio interface is set to 44.1k.
The Presonus Quantum is fine here running at 96k (plays web audio just fine).
Best Regards,
Jim Roseberry
www.studiocat.com
jim@studiocat.com
by Trucky on Tue Aug 28, 2018 8:45 am
andysmith18 wroteI have the exact same symtpoms: Quantum 2 outputs show normally on the Windows playback device window, and the meter works as if its working fine, but there's no output to the Quantum. Works beautifully in Cubase using ASIO driver.
Thanks,
Buzz
Please post your system specs and the versions you're currently running.
by andysmith18 on Tue Aug 28, 2018 11:06 am
Jim Roseberry wroteWith some audio interfaces, they won't play Web audio unless the sample-rate for the audio interface is set to 44.1k.
That was it! Windows didn't like 48K - but works fine with 41K (and 96K, surprisingly).
Thanks for your help!
And Trucky, added my specs to my signature, thanks for the suggestion.
Andy
Quantum 26x32 (1.1-8)
Intel Core i9-7900X Processor
ASUS X299-A 32MB
Samsung 960 PRO M.2 512GB SSD (x 3)
Cubase 9 Pro
by Trucky on Tue Aug 28, 2018 1:18 pm
Great suggestion @Jim Roseberry and glad to hear it's working!
by Jim Roseberry on Wed Aug 29, 2018 5:08 am
Glad that solved it...
Best Regards,
Jim Roseberry
www.studiocat.com
jim@studiocat.com
by alfonsosantimone on Tue Nov 27, 2018 3:26 pm
Hi, i can't really resolve this issue.
When i open some ASIO app if i try to play some youtube video or some media file with a media player i have to set as a default device another one (i.e. Quantum OUT1/2) and then set back again Quantum Main OUT as default device.
Definitely multiclient operation on Windows 10 are a total mess. This affects the Quantum MIDI port to. I can't have more than an app accessing Quantum's MIDI port.
Is there any stable solution?
thanks
by jonhamilton2 on Wed Nov 28, 2018 4:26 am
same issue here, still waiting for presonus tech support to reply they are aware of this issue.
Cpu: Win10/2015 Mac Pro i7@4.3ghz/SSDs
Tools: Slate VMS/Apollo X6/Antelope Audio Discrete 8 Synergy Core/Heritage Audio R.A.M.2000/API Lunchbox 6/Dyn Audio Bm5a MK2+Adam Audio
Kurzweil Forte 88/Virus TI2 61/Behringer DeepMind 12D/Powercore Virus B/Akai MPC X/Komplete Kontrol MK2/Samples/Vst
by alfonsosantimone on Wed Nov 28, 2018 4:40 am
jonhamilton2 wrotesame issue here, still waiting for presonus tech support to reply they are aware of this issue.
Good to know. My recent personal support exchange with Presonus on this topic didn't get me the feeling that they are really aware of this ;-)
Workflow-wise, this issue is really bad.
Let's wait for some driver upgrade.
by jonhamilton2 on Wed Nov 28, 2018 5:01 pm
Somethings not good about it, and I'm not sure they have a fix for it yet, as I mentioned this to them via a support ticket about 4 months ago ( presonus tech support ) and the ticket was erased by someone working there. It doesn't give me a good feeling. I came off the road only to come home to the same issue,even after updating my universal control to the latest version.
I'm using digital in/outs via an apogee rosetta ,but I've also tested it with the quantums main outs, same thing happens.
What's weird is their fix works on some setups,glad to know I'm not the only one having this issue, it felt pretty lonely.
by alfonsosantimone on Wed Nov 28, 2018 11:23 pm
Yeah, i contacted the tech support several times in the last 3 months and still get no clear answer. Just some suggestions to upgrade my system. I did it in every part following their suggestions but still the same problem. Yesterday their last suggestion is to "reset" Windows but i have a fully functional and stable system. Only thing that does not work properly is multiclient Audio and Midi with Presonus Quantum. My RME Hammerfall perfectly works i.e. So it is clearly a Presonus driver thing. I 'm really disappointed. This is not cheap hardware at all...
by jonhamilton2 on Thu Nov 29, 2018 2:06 pm
Right exactly, I'm not into the wipe an entire system out n start over just because a driver is poorly written and not tested properly. It looks like this device is going to be sold off and never to purchase another device from them again if someone doesn't answer soon enough. I'm getting ready to go on the road for 3 more months n when i GET BACK TO my recording I don't want these issues.
by jonhamilton2 on Thu Nov 29, 2018 2:41 pm
Well then now tech support doesn't take calls on interfaces, so now it's a waiting game via email support, this sucks. take heed potential buyers
by alfonsosantimone on Mon Dec 03, 2018 6:28 am
webhamster wroteGreat, thank you!
@webhamster, did you really solved the problems? I did the same as you but i can't get this sorted out. May you have some more suggestions, ideas?
thanks
