This is a followup of the post Solved: Thunderbolt is showing no thunder.
For the Sweatwater CreationStation 450. For my particular box I have an ASUS Z270-A motherboard and an ASUS ThunderboltEX3 PCIe card. Out of the box the interface did not work. With the suggestion of this Forum I fiddled with the BIOS settings (Advanced tab ---> Thunderbolt tab) until the Quantum responded. Don't know if you might need all of these settings but this is what my setting look like in the Thunder bolt BIOS section. Thunderbolt Support - Enabled Thunderbolt USB Support - Enabled Thunderbolt Boot Support - Enabled Titan Ridge Workaround for OSUP - Disabled AIC Support - Enabled AR AIC Support - Enabled Wake From Thunderbolt Devices - On Thunderbolt PICe Pwr - On Wait time in ms after applying Force Pwr - 200 Skip PCI enumeration - Disabled Skip PCI OptionRom - Disabled Skip PCI Interrupt Assignment - Enabled ACPI Removal Object Support - Disabled Security Level - User Authorization Call per boot Smi Handler - Disabled Reserve mem per phy slot - 32 Reserve P mem per phy slot - 32 Reserv IO per phy slot - 4 Native OS Hot Plug - on SW SMI on TBT hot-plug - Enabled GPIO filter - Enabled Enable LTR - Disabled AIC Location Group - sb PCIE slot AIC Location PCIEx16_3 TBT Host Router - Two Port Extra Bus Reserved - 106 Reserved Memory - 737 Memory Alignment - 26 Reserved PMemory - 1184 PMemory Alignment - 28 Reserved I/o - 32 Alpine Ridge Workaround - WA Rev 1 |
Thanks for the follow up!
Skip
