Very simple - I have an Presonus HP4 headphone amp and a Quantum 2626. I have TRS cables plugged in the back (5&6) in the line output section, then going into the input of the HP4....and get no sound.
If i plug the HP4 into the front of the 2626...the headphone outputs...the HP4 works. If it matters...using logic x and an M1 mac.
What am i doing wrong , or not understanding?
Thanks in advance,
Best
Stu
by patricebrousseau on Thu May 19, 2022 7:51 pm
Are you routing some audio from Logic to outputs 5 and 6? If you don’t, it defaults to main 1-2 and headphone…
by stu1965 on Fri May 20, 2022 12:35 pm
patricebrousseau wroteAre you routing some audio from Logic to outputs 5 and 6? If you don’t, it defaults to main 1-2 and headphone…
I have no routing in logic set up.
Main our L and R are for my speakers. Pretty sure i tried line outputs 1 and 2, and the headphones did not work. Only the front headphones output works when i plug the HP4 in those.
by stu1965 on Fri May 20, 2022 2:23 pm
im routing channels via sends in logic to line output 5&6, and the hp4 plugged into line output 5&6. This works. I guess it was different with my old firestudio.
by patricebrousseau on Fri May 20, 2022 3:06 pm
Great!
Should also work with 1 and 2 the same way.
