Hi there,
due to the fact that my bass player brain is completely washed, we miss a cable to let him play(forget it at home where It's very useful!) ![]() I only have balanced cables at home, all of them TRS-XLR May i use one to connect the bass (or guitar) to the front IN?? I have 2 doubts on the topic: 1)Normally pluggin an XLR will switch the signal to the mic preamp. Is it going to be damaged by the bass/guitar signal?? 2)the bass/guitar signal is mono, so i guess is going to be split in two, and become weaker...correct?? Thanks |
Please add your specs to your SIGNATURE. Search the STUDIO ONE 4 ONLINE MANUAL. Access your MY.PRESONUS account. OVERVIEW of how to get your issue fixed or the steps to create a SUPPORT TICKET. Needs to include: 1) One Sentence Description 2) Expected Results 3) Actual Results 4) Steps to Reproduce. OS: Win 10 x64 Home, Studio One Pro 4.x, Notion 6, Series III 24, Studio 192, Haswell CPU: i7 4790k @ 4.4GHz, RAM: 16GB, Faderport 8/16, Central Station +, PreSonus Sceptre S6, Eris 3.5, ELAC Sub, ATOM |
SwitchBack wroteI wouldn’t plug a guitar into a mic input. At best the signal will be distorted due to the impedance mismatch, at worst it will destroy the preamp. But 1-2 front IN are Mic/line/instr. so we always do that. When I plug an instrument with a TRS/TS I also have to enable the inst. switch so as to go to the preamp and not to the ADC (as far as I understand from the manual) When quantum feels a jack inside ![]() When it feels an xlr it goes to preamp (0-100) I think the risk occurs when you send a stronger signal than weaker. If I plug the drum (line) to the interface using a xlr i would push the line signal to the preamps instead of adc. Months ago I missed TRS-TRS cables to connect the drum and I did exactly the above mentioned connection. The signal was very loud but no damages thanks God (at least for the few days I used that sort of connection) |
A combo socket combines an xlr input and a jack input in the same space. But they are still two separate inputs, each with their own properties.
- Mic inputs have low impedance (1 kOhms or so) and high sensitivity (think milliVolts). These are balanced inputs (3 terminals), typically use the xlr part of combo sockets, especially if they have phantom power capability too. - Instrument inputs have high impedance (1 MOhm or so) and medium sensitivity (think Volts). Instrument inputs are not balanced (2 terminals), have no phantom power, and typically use the jack part on combo’s. - Line inputs have medium impedance (10 kOhms or so) and the lowest sensitivity of the three (think Volts or up). Line inputs can be balanced, have no phantom power, and typically use the jack part on combo’s. For a quality connection both the sensitivity and the impedance have to be compatible with the source or it can lead to weak signals, distortion or even damage. Some interfaces have a switch to toggle the jack part of the combo between line and instrument input function, but the Quantum 2 interfaces don’t have that afaik. |
SwitchBack wrote You mean the inst/line switch?? |
I see...
I have 2 quantum, not quantum 2, this is why I asked about the chance to connect the guitar with xlr..I would switch ON the inst... |
Great information
Thanks My Quantum 26x32 arrives Tuesday
Mac Mini (Late 2014)
Processor: 3.0 GHz Intel Core I7 Memory: 16 GB Presonus. Studio One Pro V4 Hardware Quantum Hardware Studio Channel II Hardware BassPOD XT Pro Hardware DBX 160a Hardware DBX 160XT Hardware DBX 231 EQ Hardware Pro VLA II Hardware WA76 Hardware Klark Teknik EQP-KT Presonus. V2 Monitor Station Presonus. FaderPort 8 "God's grace" ![]() |
