Discuss Quantum Thunderbolt Interface Here
So...I have a Quantum ordered. I was looking at cables and adapters. I have a PC with a Gigabyte Designare 390 with two TB3 ports. I own some Startech products that I like but I noted reviews for the Startech TB3 to 2 adapter has mixed reviews. The worst being that it has to be unplugged and re-plugged sometimes as devices are not always recognized. The Cablematters adapter has very good reviews and specifically mentions that the recognition issue doesn't happen as with the Startech. Very expensive at Newegg. I found it on Amazon cheaper than the Startech. I also ordered a Wavlink 2 foot TB3 cable. It has the 40gps rating that longer cables don't and gets positive reviews for quality. I have been doing electronic music since the 70's. I've seen a lot of changes. Been through the voodoo of SCSI cable management. ;) I will post here as to how it works out.
17-8700k 32gb ram Gigabyte Designare Z390 MB Quantum Interface Win 10 Pro 64
by TerjeNorway on Sun Apr 14, 2019 8:17 am
I have no problem with the unplugged and re-plugged issue. Thought that was mainly the Apple adapter. Think the Startech adapter and cable is the prefered combination for the Quantum. Never heard of the Cablematters adapter but I guess you could be lucky. That being said I don't think the adapter and cable is the the right thing to save money on..
Edit:
When I looked at the pictures of the The Cablematters adapter it looks very similar to the Startech adapter so it is probably very similar also on the inside.
My system
Asus Z170-PREMIUM motherboard (native Thunderbolt port)
Intel Core i7-6700K Skylake Processor
Corsair Vengeance LPX DDR4 2400MHz 32GB
MSI GeForce GTX 1070 Ti Gaming 8GB
StarTech Thunderbolt Cable 2M (TBOLTMM2MW)
StarTech Thunderbolt 3 to Thunderbolt 2 adapter (TBT3TBTADAP)
Neumann TLM 102 microphone
Presonus Quantum
Windows 10, Ableton 10
by PerryD on Sun Apr 14, 2019 5:22 pm
Received the Cable Matters adapter today. Not encouraging. The plastic case around the port is not large enough to accept the TB cable! I will have to get an RMA and reorder. The attached cable on the adapter is TB3 and the port is for a TB2 cable, correct? :reading:
by PerryD on Sun Apr 14, 2019 5:25 pm
The actual TB port inside the adapter looks correct. It's just the hole in the plastic case is too small or not aligned correctly to accept the cable. :/
by TerjeNorway on Mon Apr 15, 2019 2:08 pm
that is strange. You are sure you bought the right cable and adapter. What kind of cable did you buy?
It should be like this:
https://www.span.com/product/StarTech-Thunderbolt-Cable-TBOLTMM2MW-2m-White~41077
Beware of the difference between a Mini-DisplayPort and Thunderbolt 2. Mini-DisplayPort will not fit into a Thunderbolt 2 port. Be sure that the cable number is: TBOLTMM2MW
And the adapter is this right?:
https://www.amazon.com/Certified-Cable-Matters-Thunderbolt-Adapter/dp/B01D0D7QU0
That probably will work fine but if it does not buy a adapter with number: TBT3TBTADAP
Of course it could be some kind of production fault
My system
Presonus Quantum
by PerryD on Mon Apr 15, 2019 6:55 pm
I returned the adapter and cable and ordered the Startech adapter & cable. I am hoping this will work. Yes, it appeared that the Cablematters adapter case had the wrong size of hole. The port looked like a TB port but you could not even see the entire port through the hole in the case. :)
