Discuss Quantum Thunderbolt Interface Here
Given that the Quantum lacks an internal mixer, I wondered if anyone has any recommendations for a lightweight application that can be used to perform that function, for casual listening of input sources ?
by paullindqvist1 on Fri Mar 08, 2019 11:46 am
I would have loved to have the routing options available in Universal control, but I assume it relies on hardware mixing on in the device.
Im not sure if there is another software then a DAW where you can do the routing ?
by pauldormer1 on Fri Mar 08, 2019 12:25 pm
Yeah the input section and output section seem pretty distinct. They share a clock, but could be put in separate boxes! ??? We need software to connect the two.
I'll test Studio One later to see how much CPU it chomps just monitoring a basic input source. Just seems a bit OTT for basic monitoring of inputs. I did find this recommendation for this simple router:
https://lifehacker.com/audio-monitor-si ... ur-5630844
I've download from the link, not run yet not sure I can trust the source file..
Limited to stereo in / out, but should work.. ?
by paullindqvist1 on Mon Mar 11, 2019 7:33 am
If you get it to work, please report back! :-)
