Discuss Quantum Thunderbolt Interface Here
27 postsPage 2 of 2
1, 2
Hi all.
Some updates.
Given that i still think that Quantum's driver should be improved to circumvent Win7/10 problems (my RME works perfectly as a multiclient audio and MIDI device), i tried some tricks that may help Presonus to spot the problem.
This trick "improve" the multiclient audio support but not the MIDI multiclient support.
Go to "Services" and look for "PreSonus Hardware Access Service" under the "Standard" tab.
Under the "Startup Type" column right click and go on "Properties" and set the Startup type as "Automatic (Delayed Start)".
With this option i have multiclient audio operations working most of the times. Only one time i got a problem about Quantum not being seen by the system, but after a Win reboot everything went fine.
The MIDI multiclient problem is NOT solved by this so is still a issue to be spotted out.
by jonhamilton2 on Sun Dec 23, 2018 1:24 am
On xmas break, was able to just now test the above suggestion, I followed it to a T,and it still doesn't work.
PreSonus fix this bug!
by TerjeNorway on Wed Dec 26, 2018 8:43 am
I have a Quantum and the sound falls out when I'm playing a youtube video and at the same time open my DAW. But the sounds comes back after seconds so I don't see the "big" problem. Does any other driver manage to do this?
My system
Asus Z170-PREMIUM motherboard (native Thunderbolt port)
Intel Core i7-6700K Skylake Prosessor
Corsair Vengeance LPX DDR4 2400MHz 32GB
MSI GeForce GTX 1070 Ti Gaming 8GB
StarTech THUNDERBOLT CABEL 2M (TBOLTMM2MW)
StarTech THUNDERBOLT 3 TO THUNDERBOLT 2 adapter (TBT3TBTADAP)
Presonus Quantum
Windows 10 Home latest update
by alfonsosantimone on Fri Dec 28, 2018 8:55 am
TerjeNorway wroteI have a Quantum and the sound falls out when I'm playing a youtube video and at the same time open my DAW. But the sounds comes back after seconds so I don't see the "big" problem. Does any other driver manage to do this?
RME drivers work perfectly.
Presonus needs definitely to fix this bug. Quantum's drivers are unstable when multiclient operations are needed. 9 out of 10 times multiclient operations don't work. They get stucked at 48kHz for example even if try to set it to 44.1...and they works on a app only at a time.
Please Presonus fix this.
by jonhamilton2 on Wed Jan 16, 2019 4:04 pm
Thank you for confirming this!! Presonus is most definitely aware of this bug.
by alfonsosantimone on Wed Jan 16, 2019 5:21 pm
So let's hope for a fix soon!
by TerjeNorway on Thu Jan 24, 2019 10:52 am
I think this is fixed now with the Universal_Control_v2_10_0_50756 2.10.0.50756 driver update. At least my youtube sound does not disappear when I open my DAW at the same time
My system
Presonus Quantum
27 postsPage 2 of 2
1, 2
